dwell angle
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=10761
Printed Date: September-29-2024 at 5:31am
Topic: dwell angle
Posted By: baumanmt
Subject: dwell angle
Date Posted: June-08-2008 at 2:51am
I have a 351w in my 84SN can someone please tell me what my dwell angle should be, I'm setting my points gap at .017, also wondering if that is correct. Thanks, Greg
------------- gb842001
Posted By: baumanmt
Date Posted: June-08-2008 at 2:42pm
Sorry- Stupid question, the dwell angle is on the engine sticker. 31 degrees, I'm still not sure about the points gap, but it did start @ .017. Thanks
Posted By: LaurelLakeSkier
Date Posted: June-08-2008 at 5:26pm
When you adjust the dwell, you ARE changing the point gap.......it is just a more accurate way of getting the correct setting. Usually the gap is set first just to get in the ball park.
Also, remember that changing the dwell/point gap will change your ignition timing so be sure to check that out with a timing light when you are done.
Posted By: nuttyskier2002
Date Posted: June-08-2008 at 6:11pm
Also, remember that changing the dwell/point gap will change your ignition timing so be sure to check that out with a timing light when you are done. |
You are exactly right!
------------- 95 Malibu Echelon w/Mercruiser 350 Magnum Skier
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Posted By: baumanmt
Date Posted: June-09-2008 at 12:41pm
Thanks for the advice. I will check all of it before headin for the lake.
