Trans fluid change
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=1085
Printed Date: October-05-2024 at 10:17pm
Topic: Trans fluid change
Posted By: Darrel
Subject: Trans fluid change
Date Posted: December-24-2004 at 6:32pm
I have the 1.23:1 Transmission. Manual states that it takes 2 qts. to fill. After draining i put about 1 3/4 qts figuring to check and top off with most of the last qt. (didnt want to overfill). Well dipstick says i am already over full mark. Has anyone else experienced this? And why does the book say 20/20 oil and the label on the trans say dextronII?
Posted By: mrese
Date Posted: December-25-2004 at 3:36am
Just put in the same amount you take out. The benchmarks on the dipstick are designed to be read while the boat sits level in the water. If you are reading it while on the trailer, it could be macht nichts.
You can use either 20 weight,Dextron II or III (not type F). The heavier 20 weight usally provides for a quieter transmission. If you swap from one to the other, just be sure to completely flush the previous type out.
Posted By: Darrel
Date Posted: December-27-2004 at 3:29pm
That would have required me to have measured what i took out. i didnt. back to square one?
Regarding measuring on the water, how critical is this? I can measure with front jack in high and low positions and compare.
Posted By: David F
Date Posted: December-31-2004 at 12:33pm
When checking the oil level, the dipstick should be inserted loose. In other words, just insert the dipstick until the should contacts the hole...do NOT seat the dipstick. If you insert the dipstick fully, it will give you a false high reading.
