Kill switch install help needed
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=10974
Printed Date: September-29-2024 at 7:19am
Topic: Kill switch install help needed
Posted By: brittcrowell
Subject: Kill switch install help needed
Date Posted: June-24-2008 at 9:02pm
So I moved to a state where I have to have a kill switch on my '93 Nautique. I went and bought one at the local marine dealer. Never installed it last year and thought I might this year so I don’t get a ticket for it. My wifes boss got a $250 for not wearing his last year while cruising around at a wide open idle. I don’t need any extra trouble!
I've since lost the instructions, but they only said some thing about a blue wire in a Merc application anyway. Did a search here but couldn't find anything so far.
The switch I got is Saf-T-Stop:
http://tinyurl.com/5shj4j - http://tinyurl.com/5shj4j
So what’s the best way to wire this little bugger up?
Thanks
Britt
Date Posted: June-25-2008 at 7:39am
Here's Tims (TRbeng) wiring diagram. I thought that he had shown the location of the kill switch but it's not on this one. It should be wired into the purple wire that feeds the ignition.
Date Posted: June-25-2008 at 10:01pm
Thanks for the diagram Pete.
I did try and install the switch last year.
I just put in in line with the ignition breaker (the power to everything one). Then I found out the the switch is closed when in the down position and open in the up position. I thought that maybe the switch was installed backwards, but just assumed I didn't know what I was doing.
Now it sounds like the switch might be installed upside down in the Saf-T-Stop housing.
Britt
Date Posted: June-25-2008 at 11:01pm
Britt, test the switch with a ohm meter to make sure you know the on and off positions. If you don't have a ohm meter, a test light on the load side of the switch will tell you. Get a cheap volt ohm meter. They are $20 to $30. Handy tool to have around the boat, house or car.
