fiberglass mufflers
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=10988
Printed Date: September-29-2024 at 7:22am
Topic: fiberglass mufflers
Posted By: rhschnauss
Subject: fiberglass mufflers
Date Posted: June-26-2008 at 12:33am
How does one know the proper direction to install the fiberglass mufflers. I have the manufacturer sticker being read from the front of the boat to the back.
------------- rhschnauss
Posted By: SNobsessed
Date Posted: June-26-2008 at 12:51am
Does it have little louvers inside? Those should be pointing with the flow.
Date Posted: June-26-2008 at 3:43am
it has a baffle of some sort, doesnt seem to have any louvers.
Date Posted: June-26-2008 at 4:00am
A marine muffler comprises an elongate cylindrical housing having an inlet and an outlet and defining an internal volume partitioned, by an angularly disposed internal baffle, into a lower chamber in communication with the inlet and an upper chamber in communication with the outlet. A vertically disposed duct is insertably secured to the baffle to allow exhaust gas and exhaust cooling water to flow from the lower inlet chamber to upper outlet chamber. The exhaust duct may preferably be further adapted with internal structure forming a plurality of individual flow conduits or passages. The duct is preferably positioned such that a plurality of flow passage inlets are positioned in proximity to the lower cylindrical housing wall, with flow passage outlets positioned in proximity to the upper housing wall. The lower duct wall may further be adapted with sidewall apertures for improving exhaust flow dynamics therethrough.
Posted By: 81nautique
Date Posted: June-26-2008 at 9:42am
------------- You can’t change the wind but you can adjust your sails
Date Posted: June-26-2008 at 10:50am
RH - Do you have a master's degree in BS?
What a tecnical description of a muffler!
If you knew all of this, why did you ask the question in the 1st place??
Date Posted: June-26-2008 at 11:00am
If you knew all of this, why did you ask the question in the 1st place?? |
Chris, I've got a feeling that the description is copied and pasted from somewhere and RH forgot the quotation marks! The exact same thing crossed my mind when I read it. In fact, I had to read it a couple times - it sounds like a engineer with a law degree wrote it!!!
Posted By: Mojo
Date Posted: June-26-2008 at 12:42pm
Who Needs Mufflers ????
------------- 05' SV211 TE 73' Martinique had:96' SNOB had:76' Nautique had 77 Tique
Posted By: GottaSki
Date Posted: June-26-2008 at 4:48pm
I belive the partitions are supposed to be at the 12 oclock position.
River Rat to Mole
Date Posted: June-26-2008 at 6:47pm
how do you like that. the power of google. It is kinda hard to read isnt it.
Date Posted: June-26-2008 at 6:48pm
i looked and saw the channel going up toward the back. so i guess its the right direction with the upper channel toward the exit. anyone else know it to be different?
Posted By: JoeinNY
Date Posted: June-26-2008 at 6:53pm
its usually label up that is the important part of the installation, label down or towards the side prevents water from draining through acceptably..
1967 Mustang 302 "Decoy"
