Boat wont steer straight???
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=11003
Printed Date: September-27-2024 at 4:32pm
Topic: Boat wont steer straight???
Posted By: kman
Subject: Boat wont steer straight???
Date Posted: June-27-2008 at 12:35pm
'76 Southwind 20'. My 13 yr. old pointed out the other day that when we were attempting to go straight, it looked like the boat was pointing to the right. He was corret. Regardless of speed, when I try to go straight, I have to overcompensate and steer left some and the boat is pointed about 10 degrees to the right. So I am essentially pushing through the water sideways. Can a boat be out of alignment like a car? What's up????
------------- Kirk
1976 Southwind 20
Eagle Mountain Lake Fort Worth
Posted By: 79nautique
Date Posted: June-27-2008 at 12:52pm
does it have tracking fins? if so then they are bent or not aligned with the rudder.
Date Posted: June-27-2008 at 1:50pm
Kirk, What you are seeing may be normal from prop torque. It's the same thing that pulls the stern of a RH boat to port when reversed.
Posted By: BuffaloBFN
Date Posted: June-27-2008 at 2:15pm
Or maybe a bent strut? See if the prop is right in front of your rudder or if it's to one side.
Posted By: bkhallpass
Date Posted: June-27-2008 at 2:19pm
Is the boat actually turning in an arc, or is there just a load on the rudder. Many inboards, and particularly the competition slalom boats are set up with a load on the rudder so there is actually constant pressure on the rudder. You can go straight, but if you let go of the wheel, the boat will instantly turn one way or the other. This can be fixed as well if one desires neutral steering. BKH
Date Posted: June-27-2008 at 2:30pm
I feel what Kirk is describing is the boat is "crabbing". The same thing you do with a plane when landing in a cross wind. The bow is pointed to starboard when the hull is going in a straight line towards port.
Posted By: kman
Date Posted: June-27-2008 at 2:40pm
This is definitely what it feels like. I will check everything that was mentioned above. Thanks
------------- Kirk
1976 Southwind 20
Date Posted: June-27-2008 at 2:55pm
BuffaloBFN wrote:
Or maybe a bent strut? See if the prop is right in front of your rudder or if it's to one side. |
I hope it's not as it came offsite from the factory.
Posted By: behindpropeller
Date Posted: June-27-2008 at 2:57pm
You need to use more rudder peddles then.
Does it have fins? Are they bent?
Tim
