Prop install ?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=11035
Printed Date: November-17-2024 at 1:00am
Topic: Prop install ?
Posted By: mycatwon
Subject: Prop install ?
Date Posted: June-30-2008 at 8:57pm
What should the nyloc nut be torqued to?
Date Posted: June-30-2008 at 9:43pm
Tod, As long as the nut is a brass Nylock and NOT a stainless it's fine.
I've never really seen a torque spec. on the nut. Just make sure you taper is ok.
Posted By: abolton
Date Posted: July-03-2008 at 10:46pm
The nut they gave me covers the hole for the cotter pin. What should I do???
Get a castle nut?
Get a shorter nylock nut?
Drill another hole behind the nylock nut?
ABE
Posted By: nuttyskier2002
Date Posted: July-03-2008 at 11:08pm
Get a castle nut?
If you have enough thread left use a jam nut with the one they gave you.
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Posted By: p/allen
Date Posted: July-04-2008 at 12:12am
I would use a castle nut . If you were to remove the lock nut to many times ,like for testing props ,the nylon wears out . My question is ,,how many times can you remove a nylock nut befor it is worn out ? Do you feel like taking the chance of it being worn out the last time you put it on . A castle nut is much more mind easing, in my opinion .
Pat
http://i175.photobucket.com/albums/w146/72ccfan/100_5977-1.jpg - My 72 Skier
Rock River
Dixon,ILL.
Posted By: eric lavine
Date Posted: July-04-2008 at 12:46pm
nylock nuts are for a one time use unless you are a CCF guy or like me, you could put a stainless washer on there and maybe the castle will line up in a different spot, i would imagine somewhere that there is a torque spec for a 3/4 10 thread, my torque is tight as you can get it by hand and no 4x4's between the prop and the hull
