Electronic Ignition
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=1113
Printed Date: December-04-2024 at 5:14am
Topic: Electronic Ignition
Posted By: Brian
Subject: Electronic Ignition
Date Posted: January-08-2005 at 4:59pm
I just purchased a 1986 nautique and put the boat in storage (far away from home so I can't check myself). Can anyone tell me if the 1986 came standard with an electronic ignition? If not, would you upgrade to electronic? I had a 1982 with the electronic updgrade and it always ran great. Wondering if I should do the same with this one.
------------- Brian
Posted By: mrese
Date Posted: January-08-2005 at 6:57pm
I don't know about the 82 but my 89 came with points. The last time my condenser went out, two years ago, I was stranded on the water. I went ahead and upgrade, haven't had any problems since. I would keep the points and upgrade the next time there is a problem. The upgrade requires less maintenace. If you replace it before it breaks, keep the old parts in a plastic bag and keep handy as a backup.
Posted By: new86owner
Date Posted: January-10-2005 at 12:03pm
My '86 had points. I upgraded to electronic using the Pertronix kit after my points ignition failed on me and I had to get towed in by a patrol boat.
It's been working fine ever since.
http://www.vintageperformance.com/retrorockets/index.htm - Pertronix
Posted By: john33617
Date Posted: January-10-2005 at 4:35pm
if your cap is a clip down this is the one http://www.amarket.com/imptppp8.htm
Posted By: Brian
Date Posted: January-20-2005 at 12:05am
Thanks all for the response. I am going to upgrade to electronic. The boat is in storage so I will have to wait until spring unless some one can tell me what type of ignition to buy.
New86owner, is there a part or model number I should look for? Did you have to change the coil as well?
------------- Brian
Posted By: mrese
Date Posted: January-20-2005 at 12:24am
call vince at Discount Inboard Marine and he will hook you up with a Prestolite conversion kit for about 100.00 ( there is 10% discount for CCFAN if you complete the transaction online). I know with the Prestolite installation, there is no need to replace the current coil.
