Question from 88BFN
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=11296
Printed Date: September-29-2024 at 9:23am
Topic: Question from 88BFN
Posted By: BuffaloBFN
Subject: Question from 88BFN
Date Posted: July-21-2008 at 9:12am
Attached are a couple photos of what I am talking about. After we talked I decided to cut loose the stringers on the port side and see if the "hook" came out. It did not. I had my Dad stand in the boat in that area and his 200 lbs barely move the bottom. Based on that I am pretty sure it is molded in the hull to help trim. Basically it starts 18" forward of the transom and angles down so that at the transom it is 1/4" lower. I would love someone else to confirm that theirs does the same thing just for reassurance. Thanks for you help!
Jim
Posted By: eric lavine
Date Posted: July-21-2008 at 10:02am
if it bent that much you would see stress cracks in the area, cant confirm the curve but those were my first thoughts
Date Posted: July-21-2008 at 10:28am
Thanks Eric, we talked about that yesterday. I think Jim mostly wants peace of mind before he puts the floor in.
I don't remember mine having a hook at all, but I will check when I pull it out again. I may have also missed that detail on mine; too bad he can't get on the site as I bet he is doing super nice work if he caught this! He did say he's done a couple other boats but not quite like this one.
I wonder which of our 2 boats was built first...maybe there's a month code in the hull #?
Posted By: Morfoot
Date Posted: July-21-2008 at 11:14am
There is a month code in the hull ID. Not sure which one it is but I know that somebody has posted on the site the hull ID breakdown. I know it's in the owners manual if you got one.
Posted By: Luchog
Date Posted: July-21-2008 at 12:52pm
I believe most boats have this hook for quickier planning and keeping the bow down, it can also used to balance prop. rotation, i know a few race boats wich have this, and someone has mentioned that CC did this as well. Check if equal amount of hook is on both sides of the boat.
Tiges have a non hook hull wich uses a trim tab for this matter.
I'd also believe that the hook on the back along with the reversed chines is what helps trap the air beneath the hull.
Commander 351W
Posted By: 75 Tique
Date Posted: July-21-2008 at 12:58pm
Morfoot wrote:
There is a month code in the hull ID. Not sure which one it is |
http://boatsafe.com/nauticalknowhow/hin.html - hull id month code
Date Posted: July-21-2008 at 2:34pm
Ive never taken a level to a BFN, but I suspect thats normal. My '90 and '71 both have some hook over the last 18" of the hull.
Date Posted: July-21-2008 at 2:45pm
TRBenj wrote:
Ive never taken a level to a BFN, but I suspect thats normal. My '90 and '71 both have some hook over the last 18" of the hull. |
That's what he wants to hear!
