Removing V-Drive Trans
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=11456
Printed Date: September-29-2024 at 11:32am
Topic: Removing V-Drive Trans
Posted By: dcoll
Subject: Removing V-Drive Trans
Date Posted: August-03-2008 at 8:00pm
I have a 97 Super Sport and need to remove the trans. I need to remove the V-DRive unit first. I have removed the 4 mounting bolts and the 6 bolts that attach the v-drive unit to the trans. This is my question, it looks like i need to loosen the set screw and the 2 bolts that appears to be keeping the prop shaft attached to the v-drive unit. Is this the case? If so, is that all? Thank you all
------------- 1997 Super Sport Nautique
Posted By: eric lavine
Date Posted: August-04-2008 at 10:06am
are you talking about the split type coupling that slides over the shaft?
Posted By: dcoll
Date Posted: August-04-2008 at 10:58am
Yes
Date Posted: August-04-2008 at 11:39am
it does unbolt from the coupling, it uses 6 or bolts instead of the normal 4, alignment is more than critical on the v-drive boats, theyt are shrter shafts so spend the extra time to get it right
