My "new" 99 Air Nautique is missing 1 of its wakeboard racks. On the passenger side, there is a black "wake designs" (I think) rack that is secured by a removable pin into a square mount that is bolted on with 4 bolts to the cross member of the Flight Control Tower - series 2. The driver side looks to have a similar set up, as the 4-bolt mount is there, but not the rack. I have looked for some time, but have not had any luck finding this sort of rack system. I would like to only have to buy 1 more and have it match, rather than scrap the 1 I already have and get 2 new ones. I also like the placement on the cross member better than around the vertical tower pole. The attached picture isn't the best, but should give at least an idea of what I mean.
If anyone has upgraded their wake racks and is looking to get rid of something that sounds like what I have described, please let me know. Alternatively, if you know where I can find wakeboard racks that are designed to go around a FCT cross member (as opposed to the vertical tubing of the tower), I would appreciate you sharing that knowledge. Thank you.
Scott
