engine dies once warm
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=1227
Printed Date: November-22-2024 at 8:26pm
Topic: engine dies once warm
Posted By: tyler34
Subject: engine dies once warm
Date Posted: February-19-2005 at 5:28pm
hey all....got a 85 2001...when we go to the lake starts right up off the ramp...then once the engine is warm it dies(kills itself)...like choke itself out...and then it wont restart for and hour or so...let me know if you've been down this road...oh it has a 600 cfm holley and electric choke(which i think is the problem)..TIA
tyler
Posted By: jameski
Date Posted: February-20-2005 at 9:42am
Might be the coil?
current boat
http://www.correctcraftfan.com/diaries/details.asp?ID=1977 - 94 Sport Nautique
previous boat
http://www.correctcraftfan.com/diaries/details.asp?ID=601 - 78 Martinique
Posted By: David F
Date Posted: February-20-2005 at 12:47pm
Might be the ceramic resistor. jumper across the resistor and see if your problem goes away. If so, replace it...do not get rid of it.
Posted By: workky
Date Posted: February-20-2005 at 5:32pm
I had that problem,took forever to figure out what was wrong.Turned out my tach was grounded or something,causing my coil to overheat .I replaced the coil,unhooked the tach and never had the problem again.I would think that it is coil related
Posted By: kenny g
Date Posted: February-21-2005 at 1:07pm
also the tach can short out and kill the engine,but this usually is during higher RPM's.
the tach is wired through the coil.
kenny g
Posted By: 882001
Date Posted: February-21-2005 at 1:19pm
quote: Might be the ceramic resistor. jumper across the resistor and see if your problem goes away. If so, replace it...do not get rid of it.
unless you install electronic ignition.i would
kemah texas
http://www.correctcraftfan.com/diaries/details.asp?ID=163&yrstart=1986&yrend=1990 - 1988
skinautique "2001"
Posted By: Guests
Date Posted: February-21-2005 at 7:01pm
put a new coil in it...just got one from a auto parts store for a 351 windsor..gonna take it out and see what it does..i left the tach hooked up....thanks for the help..ill post what happens in a couple of days!!
Posted By: tyler34
Date Posted: February-23-2005 at 12:21am
woohooo...back in bussiness..its amazing what a $30 part will do for ya..(and some people with knowledge)....i appreciate the help...thanks again
tyler
Posted By: Guests
Date Posted: June-13-2005 at 2:24pm
Tyler,
Did you leave the resistor hooked up as original, or did you bypass it? I may be having the same problem with my 85 351W.
Posted By: Bob's2001
Date Posted: June-13-2005 at 7:15pm
I had a very similar problem with my 83. New coil and left everything else the same. Problem seems to be solved. We had a great run Saturday with no problems.
Bob Ed
83 2001
Posted By: ultrahots
Date Posted: June-17-2005 at 12:50am
Same thing here.New coil fixed it as well.
http://www.correctcraftfan.com/diaries/details.asp?ID=6960&sort=&pagenum=2&yrstart=1986&yrend=1990" rel="nofollow - 1980 Show Nautique
