Low water temp reading: new gaug
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=12338
Printed Date: September-29-2024 at 3:22pm
Topic: Low water temp reading: new gaug
Posted By: kman
Subject: Low water temp reading: new gaug
Date Posted: November-08-2008 at 9:59pm
I put a new Teleflex water temp gauge in 3 weeks ago and it hovers around 150ish even after a cruise and sudden stop. The water temp down here in Texas is around 70 right now. The old temp gauge during this past summer got up to 160 easy. Is it possible that the temp won't get to 160 because the water temp and ambient temp outside is so much colder? I was going to wait until next summer to check, but thought I would ask since a lot of you guys run up in the colder parts of the country. Bad gauge maybe????
------------- Kirk
1976 Southwind 20
Eagle Mountain Lake Fort Worth
Date Posted: November-08-2008 at 10:21pm
Kirk,
Did you put in a new sender with the new gauge? 150ish isn't bad. What temp T stat do you have in the engine?
The T stat controls the engine temp. The water temp of the lake has nothing to do with the engine running temp.
Posted By: kman
Date Posted: November-08-2008 at 10:24pm
did not put in new sending unit. I figured if it was working with the last gauge I could leave it alone. 160 T stat.
------------- Kirk
1976 Southwind 20
Date Posted: November-08-2008 at 10:26pm
I feel that new sender should always be installed when with a new gauge even if the ohm range of the sender matches.
Posted By: kman
Date Posted: November-08-2008 at 10:28pm
last dumb question. is that difficult and where is it located? OK two questions...
------------- Kirk
1976 Southwind 20
Date Posted: November-08-2008 at 10:44pm
No, it's easy. The sender will be on the front end of the intake manifold. It looks like a 1/2" hex brass pipe plug with a wire terminal in the top of it. Don't put any pipe dope or Teflon tape on the pipe threads. The sender is a variable resister that changes the voltage to the gauge as the engine temp changes. (the temp gauge is really a volt meter!) The ground for the circuit is the engine block. Tape or dope may interfere with the grounding.
Posted By: kman
Date Posted: November-08-2008 at 10:46pm
Got it. Thanks.
------------- Kirk
1976 Southwind 20
Posted By: 74SkiNautique
Date Posted: November-14-2008 at 2:28pm
I have a 150 in mine. It is fully open around 155. So while driving the gauge reads about 160, then cools back to 155 after sitting for a min.
------------- 74SkiNautique
