Fusing Bilge Pumps
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=12639
Printed Date: September-29-2024 at 5:27pm
Topic: Fusing Bilge Pumps
Posted By: Jim_In_Houston
Subject: Fusing Bilge Pumps
Date Posted: January-08-2009 at 12:33am
Should a bilge pump be fused? I think not but I would like the opinion of a boat expert.
------------- Happy owner of a '66 and a '68 Mustang
Posted By: JoeinNY
Date Posted: January-08-2009 at 12:45am
I dont know if we can find a boat expert but every bilge pump I have ever seen has been fused, every one I ever bought that was not a direct replacement comes with a fuse holder inline and a recommendation for a fairly low amp fuse (usually two amps for a smallish pump). I would suspect this is to possibly save the pump motor when it inevitably runs dry because the pump sticks or when it ingests debris and stops running and the amperage goes up enough to blow the fuse, but not nearly enough to reach the wire ratings. Now this saves a pump return to the manufacturer but might it in some cases lead to a sunken boat?
1967 Mustang 302 "Decoy"
Date Posted: January-08-2009 at 1:08am
Thanks Joe. A little scary though. Kind of makes me wonder how much one of those little pumps draw when they get locked up. They may not draw enough to heat the wiring. I would think that if they clog the amp draw goes down but who knows. I will fuse mine based on your info. Good to see your words again after a long hiatus. Jim
Posted By: 75 Tique
Date Posted: January-09-2009 at 1:57pm
Jim_In_Houston wrote:
Good to see your words again after a long hiatus. |
Dittos Jim, Good to hear from you. What you been up to? How are my old stomping grounds?
Posted By: Riley
Date Posted: January-09-2009 at 2:36pm
I had a pump lock up a few years ago. It was fused, but the fuse didn't blow. It just killed the battery. The pump just seemed to seize up, there was no blockage. It was an Atwood pump. If you ever take one apart, they've got cheap little motors.
Posted By: jbear
Date Posted: January-10-2009 at 3:21am
Holy crap....its J-I-H back from the dead...welcome back. Where ever have you been?
john
