Ski Pole Base
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=12777
Printed Date: November-19-2024 at 10:26am
Topic: Ski Pole Base
Posted By: akabulla
Subject: Ski Pole Base
Date Posted: January-29-2009 at 7:40pm
I want to replcae my ski pole with the newer model I have. I have the older pole in the boat and want to swap it out with this one. The current pole has a pin comming out of the bottom and the base in the boat is slightly larger. I need the base for this pole:
Date Posted: January-29-2009 at 8:24pm
Not sure how much luck you'll have finding a cup- might be easier to stick with the stock pole. I know someone who would make you an offer on that pylon, by the way- or offer up a very similar 97-99 style pylon in trade!
Posted By: akabulla
Date Posted: January-29-2009 at 9:08pm
Benj,
Is the base just a cup welded to a large plate? Does it look like the ones on the 89s but with a taller cup?
Date Posted: January-30-2009 at 1:54am
To be honest, Im not sure. I never inspected mine too closely when I had the floor out.
Seems like if youre not planning to run an extended pylon (since you have a tower) that using the original pylon would be the easiest way to go, no? The ring and finger look cool, too!
Posted By: Fl Inboards
Date Posted: January-30-2009 at 11:34am
Hi
I have Installed many newer ski poles and re installed delamed bases. Not a big deal.
You can order a base thru any Correct Craft dealer. If you can not get ahold of a base shoot me a e-mail, this is not rocket science.
their is however method to glassing in the base.
jody
------------- Hobby Boats can be expensive when the hobbyist is limited on their own skill and expertise.
Posted By: sanity
Date Posted: January-30-2009 at 4:56pm
Hey Jody,
How about sharing that method for those of us who will be needing to glass in?
Sanity
Posted By: Hollywood
Date Posted: January-30-2009 at 5:44pm
OR (1) - Drill/turn a hole into the bottom of that pylon to match what you already have in the boat.
OR (2) - Turn down the base to match the old pylon, so it slips in the hull mount.
Posted By: akabulla
Date Posted: January-30-2009 at 11:37pm
Yea Hollywood, I think that is the way to go! I am going to get a pin machined in to the bottom of it that matches the old one. I think it will work out well because I am putting a newer motor and dog house in and need to raise the dog house a little so the ski pole will need to be a touch taller. So if I get it machined with a pin on the bottom I can make it any height I want!
Posted By: MartyMabe
Date Posted: January-31-2009 at 4:08pm
Where are you located in NC, akabulla?Drop me an email if you need any help with any future endeavors(projects?) Later Marty
------------- 66 Skylark http://www.correctcraftfan.com/diaries/details.asp?ID=5041" rel="nofollow - 93 SN If you're not living in NC, you're just camping out!
