Removing exhaust manifold bolts?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=12802
Printed Date: October-08-2024 at 12:41pm
Topic: Removing exhaust manifold bolts?
Posted By: Dave D.
Subject: Removing exhaust manifold bolts?
Date Posted: February-03-2009 at 2:39pm
I need some advice on the best way to remove a couple of rusted exhaust mainfold bolts on my '89 PCM 351. I can get most of the bolts out with no problem but a few are siezed and the allen heads are stripped out. The manifold gaskets are not leaking but I need to remove the mainfolds to replace leaking valve cover gaskets. Please advise, thanks!
------------- Dave D.
http://www.correctcraftfan.com/diaries/details.asp?ID=5525&sort=&pagenum=4 - '89 Sport Nautique
http://www.golaketravis.com/webcam/ - Lake Travis, Texas!
Date Posted: February-03-2009 at 3:43pm
Dave,
If the socket head hex's are accessible from the top and not blind (a section of the casting close to the top of the bolt) then you may want to try one of these:
. http://www.mcmaster.com/#screw-extractors/=fzt2a - hex socket head extractors - bottom of page 2814
If not then you may be able to get a vise grip on it. If that doesn't work then a Dremel tool with a cut-off blade to cut the heads off is another option.
Do use some penetrating oil like Kroil or PB Blaster (not WD40 - worthless s***) and some heat.
BTW, on tough to break loose socket heads, never use a worn allen wrench or one of the "ball-point" hex keys.
Posted By: Dave D.
Date Posted: February-03-2009 at 6:14pm
Thanks Pete, I will give the Dremmel and/or the extractor a try. I cannot get a pair of vice grips on the bolt heads and the heads in question are very bad shape. Once I cut off the bolt heads and remove the manifold, I feel pretty certian that I can get the rest of the bolts out. Looks like I will use some anti-sieze on the new replacement bolts after I clean up the holes with a tap. I will post it hear when I achieve success. Thanks again for the tips, Pete!
Posted By: BuffaloBFN
Date Posted: February-03-2009 at 8:30pm
Another idea might be to put new hex bolts back in the places where the others came out. Snug 'em up and that will take pressure off of the others.
And maybe use a cold punch smaller than the hex head and a sharp blow for an attitude adjustment. I haven't seen what Pete posted until now, but I'd use that or an easy out after the 'adjustment'.
Posted By: 86BFN
Date Posted: February-03-2009 at 9:42pm
You could also drill the head off. once you remove the manifold it will be easer to get the rest of the bolt out.
PB blaster works great!
------------- đź‘Ł Steve http://www.correctcraftfan.com/diaries/details.asp?ID=4057&sort=&pagenum=1&yrstart=1986&yrend=1986" rel="nofollow - 86 Barefoot Nautique
89 Martinique Former Owner: 93 Hydrodyne 350 MAG
Date Posted: February-03-2009 at 9:58pm
PB blaster works great! |
Steve,
A socket head cap screw has a higher tensile strength than a grade 8 bolt consequently they aren't the easiest to drill even with a carbide bit. They are hard - min. Rockwell C39!!! Have you even tried drilling one?
Posted By: bradtm16
Date Posted: February-04-2009 at 12:15am
Once you do get them out, you should run a tap in the threads to clean out as much rust as possible. When you get new bolts, you have to go back with the allen head style, I was going to try to switch my to hex head but the head is to large. Just a little tip to save you time.
------------- http://correctcraftfan.com/diaries/details.asp?ID=1808&sort=&pagenum=1&yrstart=1982&yrend=1982 - 83' SN 2001
Posted By: Gary S
Date Posted: February-04-2009 at 12:44am
They do make stainless ones and with some anti seeze you'll never have any trouble again
Posted By: SNobsessed
Date Posted: February-04-2009 at 10:54am
Is stainless & cast iron a good mix? Sometimes different metals will have galvanic reaction. Just wondering.
Posted By: Dave D.
Date Posted: February-04-2009 at 11:47am
I tried drilling the heads off and Pete is right...it's nearly impossible even with a carbide bit. I am going to try using my Dremmel to cut them off but was wondering which particular Dremmel wheel I should use. I also plan to heat the them with a torch and wack them with a punch to set up vibration so I can get the penetrating oil to suck down into the threads as it cools. I like the idea of putting the new bolts in and tightening them to help relieve the stuck bolts.
I have never had such a hard time removing the manifolds on other(hot rod)projects. Maybe it's just a Ford thing, lol!!
Thanks for all the great imput!
Date Posted: February-04-2009 at 12:24pm
SNobsessed wrote:
Is stainless & cast iron a good mix? Sometimes different metals will have galvanic reaction. Just wondering. |
Chris,
Stainless is simply a carbon steel alloy so it's cool with the cast iron.
Dave,
You should be able to cut into the head most of the way without hitting the casting with the standard Dremel cut off wheel/arbor. Then with a cold chisel break it off (remember it's hard!!) the rest of the way. You may then need to go back at it with a mounted stone to remove what's left of the head.
Posted By: dwcar
Date Posted: February-04-2009 at 11:14pm
Dave,
I just removed my manifolds. I broke off one of my bolt heads. Luckly it was just the head and there was enough of the bolt sticking out that i could get a pair of vice grips on it. I was told to take something like an ice pick or finer and pick around where the bolt goes into the engine. I was able to get some of the rust out of the threads. I also used the PB blaster. I kept working it for about 4 days and when i tried the vice grips it came right out. good luck
------------- 83Ski
Posted By: Waterdog
Date Posted: February-05-2009 at 10:21am
Dave,
Take your time! It's easy to get frustrated with frozen bolts. Penatrating fluid, heat, cut-off wheel ect.. You'll probably use all the tools you can think of.Try to keep the colateral damage to a minimum.
------------- - waterdog -
Posted By: Dave D.
Date Posted: February-05-2009 at 12:02pm
Definately taking my time...I have been trying to drill the heads off without much progress. It's time to try some new tricks. I have a torch, chisels, dremmel, cold case of beer, etc to spend the weekend on this project. I have been very cautious not to screw up the manifold flanges.
With enough work and patience, I WILL get them off. I have all new bolts and bunch of other new goodies coming from Skidim...and spring is on it's way! I can't wait to get back out on the water for some fun in the sun. Now, if we could just get out of this severe Texas drought we are in to fill up the lake...
Posted By: 79nautique
Date Posted: February-05-2009 at 12:39pm
best thing to use is a cut off wheel on a die grinder and cut the bolt head off, then use a grinding wheel to get the rest of it.
next best is a cutting torch.
don't forget to spray PB or liquid wrench between the mainfold and block that's where the threads start, remove all of the other bolts except the one that is broke and that should create a small gap where it can wick into, it won't wick all of the way from the outside of the manifold to where the threads are after that install one other bolt at the opposite end tear out the gasket helps as well to get the the penetrating oil to where it needs to be.
Date Posted: February-05-2009 at 12:59pm
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/AttachmentsDetail.aspx?pid=426 - use this if you are using your dremel tool
cut an x in the head and then use your cold chisel to pop them off the rest of the way if you cannot get to it to cut it off perpendicular to the thread body.
Posted By: Dave D.
Date Posted: February-05-2009 at 2:15pm
Great advice '79, that makes sense. I believe I have some of those fiberglass cut off wheels. I am off on Fridays so I should have the manifolds off by tomorrow afternoon. It's amazing that something made of fiberglass can cut hardened steel! Stranger things have happened, I guess.
Posted By: Waterdog
Date Posted: February-05-2009 at 6:15pm
79,
I forgot the X-cut trick. Removed a lot of chassis rivets like that. Cut a X then use a rivet gun with a chisel. Oh wear ear plugs!
Posted By: Dave D.
Date Posted: February-10-2009 at 12:57pm
The x-cut worked like a charm...I was able to cut off the heads of four bolts that were bad. I was able to pull the manifold off over the studs and then used vice grips to easily remove the studs. Luckily the other side's manifold came off without any trouble. I have seperated the manifolds from the risers and will sandblast, prime, and re-paint them along with all new bolts, gaskets, and fittings. I might as well detail the engine block while I have it apart. Thanks for all the great advice you guys gave me. It won't be long and I will be back on the lake with a sweet running Correct Craft!
Posted By: 81nautique
Date Posted: February-10-2009 at 1:03pm
Dave, I use High temp disk brake caliper paint on my manifolds. It will still burn off down low by the exhaust ports but otherwise it holds up very well and has a nice gloss to it.
------------- You can’t change the wind but you can adjust your sails
Date Posted: February-10-2009 at 2:13pm
the riser and manifiolds need to be diped and cleaned so the internals are clean.
the manifolds needs inspecteced for rust and possible faulure area's and replaced if needed.
Risers rairly go bad unless used in salt or brackish water so cleaning, internally, is all that is ever needed.
the manifolds see tons of heat and can rust faster and fail aka crack and leak. With the risers removed you should be able to see the internal passages to a degree and a small mirror helps as well. But you can inspect and if you remove the rear drain plug and see lots of rust flakes then it's time to concider replacing before you hydro-lock the motor from a cracked leaking manifold and have to spend way more than the three hundred or so to get new PCM's
Posted By: Dave D.
Date Posted: February-10-2009 at 4:26pm
I agree. I plan to dip these parts and will inspect for any damage. This boat has spent it's life running two lakes in our area that are full of hard calcium water so I do see a lot of white build up on the inside of the risers. I might try soaking them in CLR before dipping them just to see how much of the hard deposits I can remove.
I had one of the stock manifold drain plugs that was stuck like chuck so I drilled it out. I found some nice brass 3/4" plugs with outer square bolt heads at Lowes to replace the stock recessed type of plug. This will make removal of these things MUCH easier. I can't wait to get these things restored and back on the boat.
Next up, I plan to pull the prop and get it to the Nettle's Prop Shop for a re-do. While I have it off, I want to replace the strut bearing and check my alignment. After that, I should be good to go for the summer.
Posted By: Dave D.
Date Posted: February-25-2009 at 3:06pm
Update: I seperated the risers from the manifolds and hot tanked them and then sandblasted them. I took them to a local machine shop to have them re-surfaced. It's very important to do this! It cost me $100 which I thought was a little steep, but those guys have to eat too. I then sprayed everything with some good automotive self etching primer and then two coats of hi-gloss/hi temp black spray paint. I got all new bolts, gaskets, and fittings from skidim.com. I also installed new corregated rubber hose. The thing looks brand new! She's going in the water on Friday for a shake down cruise. I am also gonna test my new speedo gauge and pitot. Woo hoo, spring is almost here! It's supposed to be 85 degrees today...
Posted By: Hollywood
Date Posted: February-25-2009 at 3:20pm
Dave D. wrote:
I found some nice brass 3/4" plugs with outer square bolt heads at Lowes to replace the stock recessed type of plug. This will make removal of these things MUCH easier. |
You're saying you replaced the square socket plug
with a square head plug?
I like the top one better. The bottom variety seems much easier to strip. Don't overtighten and you won't have any problems with either.
Posted By: Dave D.
Date Posted: February-25-2009 at 3:27pm
Yep! The plugs on mine were turned at a position that I could not get a tool on them. They were obviously on there for a long time and one of the square pockets rounded out. I had to drill it out to remove it. The new ones get some anti-seize and just the right amount of torque to keep from over tightening. With the outer boss...it's MUCH easier to get a tool on them when they need to be removed for winterizing.
Date Posted: February-25-2009 at 3:41pm
What kind of tool(s) were you using? All you need is a 1/2" drive socket wrench. I do agree that you will have an easier time removing a stripped square head over a square socket plug.
Posted By: Dave D.
Date Posted: February-25-2009 at 3:47pm
I tried using a piece of square steel that was the proper size and bent on the end like an allen wrench. I also tried a 3/4" rachet extension (without a socket) on it. The problem is with very limited clearance due to the low swept riser that will not allow you to get the tool on it. Whoever tightened it last, left the plugs in just the right position to make getting a tool on it impossible. I even tried using vice grips on the outer diameter of the plugs, but they were stuck like chuck. Even with PB blaster and tapping them to set up vibration, no dice.
With the new plugs I am using, any old wrench will work, no matter what position they are in.
Date Posted: February-25-2009 at 4:16pm
You were not able to get a 1/2" drive socket wrench in the old plug? I've never had a problem with mine.
Date Posted: February-25-2009 at 4:37pm
Dave D. wrote:
The problem is with very limited clearance due to the low swept riser that will not allow you to get the tool on it. |
You should have followed HW's advice and used a regular 1/2" drive ratchet on it. Works perfectly on the low swept PCM risers.
Posted By: seacamper
Date Posted: June-01-2014 at 11:28pm
79nautique wrote:
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/AttachmentsDetail.aspx?pid=426" rel="nofollow - use this if you are using your dremel tool
cut an x in the head and then use your cold chisel to pop them off the rest of the way if you cannot get to it to cut it off perpendicular to the thread body. | Hey All, Can anyone show me what this tool is? The link does not work. I am running into the same situation. I need to get a couple manifold bolts off. Tom
------------- 1980 Ski Nautique Boat Bar 1988 Mastercraft Tristar Open Bow 1988 Mastercraft Tristar Closed Bow 1969 Seacamper Houseboat 1986 Harris Pontoon 2004 Seadoo GTX SC + Flydive Xboard 1999 Adventurecraft
Date Posted: June-01-2014 at 11:33pm
seacamper wrote:
Hey All, Can anyone show me what this tool is? The link does not work. I am running into the same situation. I need to get a couple manifold bolts off. Tom | "Dremel" is a cheap homeowners die grinder.
Date Posted: June-01-2014 at 11:50pm
I think the link probably showed a cutoff wheel. Get the reinforced ones, the cheap ones shatter very easily (wear eye protection, of course).
BTW Pete, my Dremel may be a cheap homeowners tool, but it is 30 years old, still running on the original brushes & has been run hard many times. It has been a great tool.
Date Posted: June-02-2014 at 12:05am
So just take a cutting wheel and cut an x in the head,and then whack it with a cold chisel?
Date Posted: June-02-2014 at 12:09am
8122pbrainard wrote:
You should be able to cut into the head most of the way without hitting the casting with the standard Dremel cut off wheel/arbor. Then with a cold chisel break it off (remember it's hard!!) the rest of the way. You may then need to go back at it with a mounted stone to remove what's left of the head. |
Date Posted: June-02-2014 at 12:17am
OK, Keep your fingers crossed!
Date Posted: June-02-2014 at 6:57am
SNobsessed wrote:
BTW Pete, my Dremel may be a cheap homeowners tool, but it is 30 years old, still running on the original brushes & has been run hard many times. It has been a great tool. | Chris, You are correct. I should have used the term "inexpensive" rather than "cheap". I too have enjoyed having a Dremel. I used to think of them as a gimmick until I bought one for a project and found out how handy they are. I've never had issues with brushes but rather bearings. The bearings went out on my first one so I just went out and bought a second Dremel kit.
Date Posted: June-02-2014 at 4:29pm
So, the Dremel works great. I actually had to cut the bolt sideways against the manifold, because I could not cut an x because the bolt was so far gone. Anyhoo, the larger reinforced wheel was able to cut right up to the manifold and then I followed it up with a number of shaped stones, and it popped right off. I soaked it with PB Blaster, let it sit, and when I hooked up the vise grips, they slid right out. Thanks Guys. Tom
Posted By: backfoot100
Date Posted: June-02-2014 at 5:35pm
Good to hear Tom. Damn, I forgot all about telling you that the reinforced wheel would probably work best but I'm glad you figured it out. I have an air compressor with a cutting tool but that thing just wouldn't get in that tight space at all so no reason to mention it. It's always available if you need one though.
Again, let me know if you need any help. I'll do whatever I can.
Eddie
Date Posted: June-03-2014 at 12:11pm
| Hey Eddie, I actually used this as an excuse to go to Harbor Freight and buy a small die grinder and some diamond grinders, but the Dremel actually worked better! Thanks again for the advice. Tom
Posted By: Rockymtnsalom
Date Posted: June-08-2014 at 2:37pm
I ran into this issue when replacing the manifolds on my 1970 ski nautique. I used a grinder to take off the head of the bolt and the with the manifold removed used vice grips to unscrew the base. This probably wasn't the correct way to go about it but it worked well for me
Posted By: oldcuda
Date Posted: June-08-2014 at 2:42pm
I did much the same but drilled 3/16 hole in center of head as pilot then 3/8 till the head popped off then vice grips to remove what was left after removing manifold.
Posted By: ChowHound
Date Posted: June-10-2014 at 10:09am
I realize the thread revolved more around stuck bolts (which is a good topic) but, the OP was doing this to change valve cover gaskets.
For others reading, you may want to try a swivel socket to access valve cover bolts. Not a socket with a swivel attached but a socket with the swivel built in.
http://www.amazon.com/TEKTON-4963-Impact-Universal-3-Piece/dp/B000NPT6IE/ref=sr_1_1/189-9134765-7127868?ie=UTF8&qid=1402400783&sr=8-1&keywords=swivel+socket
The U-Joint type are narrower than the ball/cup type like sears has.
I was able to easily access the valve cover bolts to snug them up last year (87 nautique). I believe you could get them off without removing the manifolds...but, I could be wrong.
YMMV -Chow
Date Posted: June-10-2014 at 11:32am
You are correct. I've done it before too using standard 1/4" drive tools. I slid the socket in from the front, it won't drop down from the top.
