Synthetic Oils?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=1305
Printed Date: April-16-2025 at 3:31pm
Topic: Synthetic Oils?
Posted By: Bradley950
Subject: Synthetic Oils?
Date Posted: March-08-2005 at 3:34pm
I was wondering if any has coverted to synthetic oil in an older Nautique? Is this a good idea? What are the pros and cons of this convertion? -Brad-
Brad Miller
bradley950@yahoo.com
Posted By: 79nautique
Date Posted: March-08-2005 at 5:11pm
You are going to get a lot of different openions from a lot of people. Me personally I wouldn't use it. It's not worth the extra cost and I change my oil every season whether it needs it or not.
If the engine is newly re-built ok but if it is old with a lot of hours use at your own risk and cross your fingers you don't spin a bearing using the syn oil. My friend found out the hard way and smoked a brand new Rehr-Morrison 500 cubic inch race engine for his Super comp dragster nothing like wasting 40K in 5 seconds.
Posted By: Tim D
Date Posted: March-08-2005 at 6:22pm
If you use synthetic in an engine after using regular oil, it can develop leaks.
Tim D
Date Posted: March-09-2005 at 12:53am
So ther are not really any advantages? So far nothing good. Brad
Brad Miller
Posted By: David F
Date Posted: March-09-2005 at 1:04pm
Brad:
79nautique got it right...many different opinions...here's mine. Go ahead and make the switch and if what Tim D says happens, then you can switch back again. The leaking issue is caused by seals shrinking a bit with the use of synthetics. So, marginal seals may start leaking. If you go back to dino oil, the seals will swell again and the leak will stop.
I think the spun bearing thing is just coincidental or a very rare occurance.
With all that said, I have nothing against dino oil when changed yearly at the least or more often depending on the use of the boat.
Posted By: Jim_In_Houston
Date Posted: March-09-2005 at 1:49pm
I am no expert and I know nothing about engine oil but here is my story:
I decided to use synthetic oil in my auto (with 30,000 miles already clocked). The engine immediatly began to blow a small, hardly noticable, amount of smoke out of the exhausts - but it was noticable. The engine began to consume oil.
I switched back to non-synthetic oil and the smoke DID NOT go away. The car smoked until I sold it.
I have no idea if the smoking problem was related to my switch to synthetic but to this day, I stay away from it. When new cars start arriving with synthetic oil I will at that time, switch to synthetic.
Date Posted: March-09-2005 at 2:29pm
Syn oil is overall thinner thus the oils leaks and you get spun bearings. Or maybe a better term would be the surface tension is less i.e. small diameter droplets. Making it easier to pass throught smaller gaps in oil seals thus your leak and with the Syn improved properties it holds on long and takes a lot longer to burn off thus the smoking car even though you replace with Dino oil.
David F   "I think the spun bearing thing is just coincidental or a very rare occurance."
It is no fluk or rare occurance and will happen every time. Syn Oil cannot fill the gap in worn or loose fitting bearings. Racing engine bearing clearances are by far much greater than what you will find in a automotive engine when both are brand new. For instance a new LT1 crate motor will have clearance from say .0005" to maybe .002" where a race engine or even a 50K mile engine are more like .003"-.005" and syn oil cannot fill this gap and you will spin the bearings. Maybe you have 40K to burn. But if I buy a new motor and expect it to run for the year in race conditions and then your first week-end out and you make two runs and the motor is junk becuase of a spun bearing. You look in to why and the person that made it looks into why and it is clearly oil failure you will change your mind. It's not like these guy are shade tree mechanics like a lot of you, these are proffesionall engine builders that have multi-milion dollar deals riding on how will there engines perform.
Brad my advise to you is
if Dave wants to buy you a new motor when yours puks for using Syn oil go a head and use Syn oil. Otherwise stick with the cheap dino stuff.
Posted By: kenny g
Date Posted: March-09-2005 at 2:33pm
leaky seals & gaskets.
http:// bestsyntheticoil.com
pretty good article.
kenny g
Date Posted: March-09-2005 at 3:04pm
I think I will stick to dino. Thanks for all your help on this matter. -Brad-
Brad Miller
Posted By: Tim D
Date Posted: March-09-2005 at 3:38pm
Put some Lucas oil treatment in with your dino oil. I used Castrol Synthetic in my truck from day one. At about a 140,000 miles it started leaking around the crank seal and the oil pan. I switched to regular 10w 40 and the leaks have almost stopped. And it jumped in price just like regular oil, but there's no petroleum in it. I spent a lot of extra money on oil without any benifit as I see it. I changed it every 3500 miles which was about 40 times at $5 a quart is $1,000 not counting the filters. I drove my Z car 267,000 miles on dino oil and it never smoked or leaked. I will not be putting any in my 4Runner.
Tim D
Posted By: David F
Date Posted: March-09-2005 at 4:06pm
79Nautique:
We are talking about marine engines here (nor racing engines). I admit, I have no experience with racing engines. Now, I use synthetic oil in ALL my engines, including my '77 Martinique (351W) and have been for years. None of my engines burn oil. The boat engine leaks a bit of oil at the rear main seal, but did with Dino as well. Here are list of vehicles I have used synthetic oil in over the years:
'88 BMW 750iL *
'98 BMW 740iL *
'02 Suburban *
'77 CC Martinique *
'71 Chevy Camaro (with 370hp LT1 engine that I built).
'87 Jeep Cherokee
'80 BMW 633CSi *
* means I still have the vehicle with NO problems. So, my real world experience says synthetics do NOT cause problems. I will say that if a new engine came with Dino, then Dino should be used until the rings have fully seated. Otherwise, the synthetic can prevent the rings from wearing in properly and lead to excessive blow-by or oil consumption.
Like I said, I have nothing against Dino oil and it took me a long time to change from something I had been doing for many years.
Date Posted: March-09-2005 at 5:43pm
Well the reson I even considered the convertion was the friction reduction. Since friction is just wasting ponies. Can you tell me about any prefomance gains or losses. Dose it help on gas? Magazines have articles with dyno proven power gains due to syn. oil. They also say there is a heat reduction are the combustion chambers. I don't know if the are just trying to sell oil. -Brad-
Brad Miller
Posted By: Tim D
Date Posted: March-09-2005 at 6:20pm
Horsepower or mileage thinner is better. The new Hondas come with 5w 20 oil to help with mileage. The most friction happens during start up before oil is pumped to the top of the engine. Lucas oil helps oil stay attached to parts at the top. From my experience, I will stick to dino oil.
Tim D
Posted By: David F
Date Posted: March-09-2005 at 6:22pm
I have never noticed any HP gains or increased fuel economy. I made the switch to allow long periods between oil change without the resultant lose in oil performance. I usually go 10,000 miles between oil changes now whereas I only go 3000-3500 with dino oil. With several vehicles, I got really tired of changing oil all the time.
Date Posted: March-09-2005 at 6:43pm
Dave
How many miles where on the engines when you started using Syn? I'm betting they where pretty new or freshly overhauled in all cases.
Lets pay three times has much and go twice as far not a lot of savings in the long run. And agin if it is a new engine or freshly re-built then ya you can get by using Syn. and not see a problem with nornmal driving. Put a heavy load or a constant load and things change quickly. A car engine is loaded only at take off and the faster you go the less power is required to maintain that speed. On a boat the load is always there and never decreaces thats why you'll never see a vacume advance dist. in a boat unless some dumb ass replaced the factory unit.
Posted By: David F
Date Posted: March-09-2005 at 8:13pm
Hmmm. Mileage when synthetic first used: '88 750iL +/- 90k. '98 740iL +/- 102k. '80 633CSi +/- 70k. '02 Suburban +/- 20k. '77 Martinique +/- 350 hours. '71 Camaro can't remember. '87 Jeep Cherokee not sure but I think around 140k. I got rid of the Cherokee at 165k and I had to fix a leaky front seal and head gasket due to oil leaks. It burned about 1 quart of oil in 10k miles. So, no not new engines. Never a spun bearing and not really indicative seal problems.
BTW, viscosity is viscosity no matter if synthetic or dino, so your previous comments of synthetic being thinner have me puzzled. I will agree that synthetic oil molecules are smaller than dino (clumped together), but that is ONE reason it is superior as it can better coat and penetrat the irregular metal surface.
Oh well, to each his own. Feel free to comment as much as you wish, but I have said all I feel relative to this thread.
Almost forgot to mention that I pulled my '77 Martinique with the Cherokee from the time it first saw synthetic oil until it was sold. Since I live in Austin, Texas which has many hiles, the Cherokees engine was worked very hard indeed.
Posted By: IrishFooter
Date Posted: March-11-2005 at 2:51am
I tend to be rather anal about changing oil. I got that way due to my uncles farm where maintanance was job one. All of our equipment is greased daily (when used) and oil changed exactly as reccomended. WE use John Deere Torque Gard oil and have machinery that we bought new in the 60s and 70s that has now power loss or smoking. Some of these Deeres have 8000 and better hours! I wouldnt use a synthetic oil as it isnt reccomended by my owners manual. As previously mentioned the engineers and designers of this equipment arent shadetree mechanics either and as such I have to assume that they know a lot more than I do. Anecdotal evidence aside (my old tractor, boat, car, truck etc ran for 1,000,000 miles with synthetic or dino) The engineers and designers know a lot more than we do and I gotta go with the theory if its not in the book dont do it. Perhaps some new car manuals reccomend the use of synthetics but I still wont use them- I like to have fresh oil in my engine.
1979 Ski Nautique
Posted By: nates78ski
Date Posted: March-11-2005 at 9:42pm
you must be carefull about using automotive oil in older marine engines. the major problem yuo will encounter is that marine engines run at a cooler temp that auto engines. the chemical packages that comprise motor oil for auto engine need 180+ degrees to work properly. at one time mercruiser started using multigrade oils in engines and where having lifter & bearing failure. i suggest you use a straight 40w oil.
Nathan
http://correctcraftfan.com/diaries/details.asp?ID=1463&sort=&pagenum=3&yrstart=1978&yrend=1978" rel="nofollow - My '78 Ski Nautique
<a href="http://photobucket.com/Nates78ski" rel="nofoll
Date Posted: March-15-2005 at 5:48pm
Thanks C.C.F. for all your help!! -Brad-
Brad Miller
Posted By: SkiLew
Date Posted: March-16-2005 at 12:07pm
Please give me a little more detail about why 40w oil is better than 10w-40wt. I thought the most wear occurs during start up so you would want the advantage of the multi viscosity oil for those cold starts. I am not disagreeing just looking to be better educated.
Date Posted: March-16-2005 at 7:33pm
Well lets start with ambient temperatures in the operation of boat engines. The cold start problem in autos occurs @40 degree & lower ambient temps. The bearing material in marine engines is different than modern auto engines, more like heavy duty truck application.
I would not worry about cold starting as to high filming load on the bearings @normal operating rpm & temp. Marine engines are making horsepower(load) anytime the boat is under power and all the time the boat is under power. Auto engines load highly on acceleration by once you are up to speed, with 3,4, 5 speed transmission the engine horsepower to maintain speed are greatly reduced. The ratings on oil, ie sh,sl,etc pertain to chemical packages & properties relating to specific needs of auto engines. You will find that heavy duty truck(diesel) engine use different formulation that auto & light trucks. Check out the specs in these examples see what you find. Also the viscosity of multigrade oils are not related to oil thickness but the properties the certian weight oil perform.
Nathan
