leak in transmission
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=13071
Printed Date: September-29-2024 at 7:20pm
Topic: leak in transmission
Posted By: Robert F
Subject: leak in transmission
Date Posted: March-18-2009 at 7:21pm
1993 SPORT NAUTIQUE PCM 40A 1.23/1 92-12714
I have a transission leak. When I pulled the flange apart to check for aligment oil came out between the flanges. I guess that this meens that the rear seal is bad and needs to be replaced. Should I also do the front seal at the same time, and what about the damper plate. Is it time to change it or do I wait till I need a transmission rebuild ? I do not have any noise from the damper plate!
------------- 93 Sport Nautique
Posted By: Robert F
Date Posted: March-18-2009 at 9:01pm
I have the transmission out and in the back of my truck.
Posted By: eric lavine
Date Posted: March-19-2009 at 10:15am
its not your rear seal, its the flange nut washer leaking, normally you put a bead of silicone on the nut washer on installation. its leaking between the splines...you need a 36mm skinny socket to remove the nut
how many hours? how far did you let the oil leak down? no doubt i would change the damper, just because
Posted By: Robert F
Date Posted: March-19-2009 at 7:44pm
I have 816 hours on the boat. I allways check the oil in the transmission every day that I run the boat.I do not think that the transmission was ever low on oil, at least not on my watch.I bough this boat Jan 07
Date Posted: March-20-2009 at 12:49am
definitely put a damper in while its out, front seal wouldnt hurt either
