battery recomendations
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=13297
Printed Date: November-17-2024 at 2:47pm
Topic: battery recomendations
Posted By: phospher
Subject: battery recomendations
Date Posted: April-10-2009 at 3:01pm
i know this has come up several times here but i'm not having much luck with this sites search function.
351W no sterio, battery only used for starting and filling fat sacks. what battery should i get? i'm not looking to spend the money to get an optima. right now, i have an AC Delco voyager deep cycle.
thanks,
Posted By: 79nautique
Date Posted: April-10-2009 at 3:33pm
well you need a non-deep cycle battery version of the voyager or the optima,   Dekka suppose to be decent, heard others like interstate batteries too.
I'm parcial to Delco's mainly because I used to work for them but the battery business is now owned by Johnson controls and GM is out of the battery business, except for lithium ion and nickle metal hydried (sp) battery's
Posted By: TX Foilhead
Date Posted: April-11-2009 at 12:58am
I've had a Red Top Optima in my boat for 4 years with no problems, and I have never put a charger on it (use it at least every other week in the winter). You might want to reconsider the no Optima thing.
Posted By: Randy_in_Ohio
Date Posted: April-11-2009 at 2:02am
ditto on the Optima...
http://www.correctcraftfan.com/diaries/details.asp?ID=1602&yrstart=1991&yrend=1995" rel="nofollow - 1993 Sport Nautique
Posted By: bkhallpass
Date Posted: April-11-2009 at 3:27am
I don't know if it is a good battery or not, but the battery that came stock in my boat was a Nautilus and it lasted 8 years. BKH
Livin' the Dream
Posted By: phospher
Date Posted: April-14-2009 at 2:25pm
ok, i'm sold on the optima. the redtop 34R 800CCA?? should i get that one?
Date Posted: April-14-2009 at 3:28pm
BLUE TOP NOT AUTOMOTIVE RED TOP
Posted By: phospher
Date Posted: April-14-2009 at 3:34pm
ahh, but aren't the blue top deep cycle?
Posted By: phospher
Date Posted: April-14-2009 at 3:39pm
should i get the optima blue top 34M? looks like that's a starter battery.
Date Posted: April-14-2009 at 3:56pm
Phil,
You won't go wrong with ether the red top, yellow top or the marine blue top. All the optimas due to their design can handle lots of pounding and vibration. The red top is recommended for off road so it sure will handle the abuse of marine service. I'm running a red top in my Tique without any problems. The yellow is a cross between starting and deep cycle so if you are filling sacs, it's not a bad choice. Yes, the blue tops are a deep cycle and should be used for such but are also listed as a dual purpose. The blue top does have the stud terminals as well as the lugs. Confusing isn't it!!
Posted By: phospher
Date Posted: April-17-2009 at 2:21pm
yeah, it is a bit confusing. i'm going to go buy one today and i don't know which one i should get. so which are the cheapest? lol
Date Posted: April-17-2009 at 3:34pm
Phil,
If you don't need the dual connections (stud and lug) that's on the marine blue top and you are using it primarily for starting (you'll probably have the engine running when filling sacs) then I'd go with the red top.
Date Posted: April-17-2009 at 9:42pm
There are 2 versions of the blue top, one is dual (like the yellow) and the other is deep cycle. My Optima that has lasted so long is a red top, no stereo in that boat so no need for a deep cycle.
Posted By: phospher
Date Posted: April-18-2009 at 3:57am
well, in the end i cheaped out and got a everstart maxx marine from walmart. 875 CA's. I figured since i'm planning on a new boat next year it wasn't worth to spend the extra cash.
so i picked up my boat from storage and threw the new battery in it. she fired up pretty quick after her long beauty rest. but she was ticking for a while until the oil got up there then she quieted down. the valves were probably ticking for 20 seconds or so... i took a few hot laps around my lake and took my 7 month old on his first boat ride. boat ran perfect as i expected. for some reason i always hold my breath when i go to fire her up for the first time of the season. but after she starts, i'm reassured again that a correct winterization pays off.
Posted By: lonestar
Date Posted: April-20-2009 at 8:38pm
OK here is a newbie question. Why no deep cycle ?
lonestar
Posted By: SNobsessed
Date Posted: April-20-2009 at 9:12pm
Deep cycle batteries do not have high amp delivery capability, so they do not work well for starting a V8 engine. They are good fro trolling motors & stereos, however.
Posted By: pwningjr
Date Posted: April-20-2009 at 9:32pm
To clarify (I can do that; he's my dad ):
Deep cycle batteries are designed for low amp draws over extended amounts of time, starting batteries are designed for high amp draw in a very short time. Using a deep cycle battery as a starting battery will [significantly] shorten its life span.
Jay
"Proud to be a geek"
Big Heavy (stephan): One can't always be perfect when water dancing on your shred stick.
Date Posted: April-21-2009 at 12:55am
He's getting close to overtaking me!
Posted By: rosconole
Date Posted: April-23-2009 at 4:37am
i do find it helpful to have the blue top d34m with the extra ring terminal spots for stereo hookup and whatever else i want, its funnny how the red top is 3 yr free replacement and the blue is 18 months...i always get them free replacement in my diesel 7.3 since it just kills batteries like a duck running into steel shot.
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
Date Posted: April-23-2009 at 9:46am
Are you putting the blue or red top in the truck?
Date Posted: April-23-2009 at 2:02pm
you need a catapiler battery in that thing and you'll be fine.
