Engine Drain Plugs
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=13481
Printed Date: November-17-2024 at 2:43pm
Topic: Engine Drain Plugs
Posted By: LakeWI
Subject: Engine Drain Plugs
Date Posted: April-27-2009 at 5:23pm
Hi,
A friend winterized my 98 Ski Nautique last year. I am reinstalling the engine drain plugs and have an extra plug. I installed two at the back of the manifolds. One on the side of the engine block behind the drivers seat and one under a pipe in front of the engine. Is there one more that I am missing? Thanks.
LakeWI
Posted By: 79nautique
Date Posted: April-27-2009 at 5:29pm
passenger side towards the rear of the block around cylinder number 8 is the one your missing.
also there is one in the tranny cooler as well.
Posted By: Hollywood
Date Posted: April-27-2009 at 5:35pm
engine block passenger side?
Is it the same plug as the block and pipe plugs?
Date Posted: April-27-2009 at 5:36pm
Monty,
You may or may not have a plug on the cooler -some don't. Even if it does have one, most will just disconnect the raw water line on one end to drain it. I just wanted you to know in case you go looking for a extra plug!!!
Welcome to the site.
