Transmission Manual
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=13497
Printed Date: November-17-2024 at 2:49pm
Topic: Transmission Manual
Posted By: tmacdonald
Subject: Transmission Manual
Date Posted: April-29-2009 at 11:12pm
Does anyone have a service manual for a PCM Transmisson 1.23:1. My tranny is noisy in neutral and at low speed so im gonna pull it and take a look but it would be nice to have access to a manual if I need one. Thanks
Posted By: 86BFN
Date Posted: April-30-2009 at 12:19am
Welcome. Did you look in the Reference Section?
👣 Steve
http://www.correctcraftfan.com/diaries/details.asp?ID=4057&sort=&pagenum=1&yrstart=1986&yrend=1986" rel="nofollow - 86 Barefoot Nautique
89 Martinique
Former Owner: 93 Hydrodyne 350 MAG
Posted By: eric lavine
Date Posted: April-30-2009 at 12:23am
replace your damper, make sure your engine is running correctly, and your problem will be cured
Date Posted: April-30-2009 at 2:45am
Yeah I checked the reference section and there was no manuals for the PCM trannys. Is there a way to check the damper once I have pulled the trans to confirm its failed? Then engine is running fine. I bought this boat last summer and only used it once. When I test drove it the previous owner said that the noise had always been there and the nautique dealer said there was nothing wrong. I have been around nautiques a while and never heard that noise so I thoght I would investigate before things got worse or summer arrived.
Posted By: kapla
Date Posted: April-30-2009 at 2:50am
I would take eric words for granted..he is our tranny expert
welcome to the forum
<a href="">1992 ski nautique
Date Posted: April-30-2009 at 4:07pm
SkiDIM sells the manual.
