transmission oil type SN 1992, pcm-40a
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=13526
Printed Date: November-18-2024 at 5:30pm
Topic: transmission oil type SN 1992, pcm-40a
Posted By: rogier
Subject: transmission oil type SN 1992, pcm-40a
Date Posted: May-02-2009 at 8:50pm
On my 351 pro-boss (1992 Sport Nautique) there is a PCM-40a 1.23:1 transmission, 530hrs. After 500hrs The previous owner replaced the transmission oil with generic oil for automatic transmissions.
I want to replace the oil to be sure the right oil is in there. I plan to replace the oil three times, every 10hrs, to make sure the old stuff is out.
My questions:
1 - What is the standard oil for this transmission?
2 - What is the best oil for this transmission, since I'm fully replacing it anyway?
Dextron Iv, Dextron 3, other? And what brand / exact specification is needed? (I have to buy it in Europe, the more details the better)
Posted By: eric lavine
Date Posted: May-03-2009 at 11:42am
anything compatable with Dexron/Mercon it will say so on the bottle
Posted By: rogier
Date Posted: May-03-2009 at 2:10pm
Thanks Eric, but I have dexron 3, 4, 5 and now even 6 available! what number?
Date Posted: May-03-2009 at 2:46pm
it should say on the bottle "compatible with Dex/merc
just no synthetics on the bronze plates, check your alignment too, forget about the alignment times are tough lol
i think 3 is compatible but pretty sure 6 is not
Date Posted: May-04-2009 at 1:11pm
Just like Eric said- Dex III or equivalent. Stick with conventional. Avoid synthetic and high mileage formulations. I prefer Valvoline.
Posted By: gcarbone
Date Posted: May-09-2009 at 11:52am
I have heard of guys using a baster or some type of vaccum pump to drain/remove the old fluid - sound about right?
------------- 96 SN
Date Posted: May-09-2009 at 12:15pm
yes
Posted By: rogier
Date Posted: July-10-2010 at 8:53am
Replaced the oil 2 months ago, found original 20W20 oil with PCM mentioned on it and decided not to spend lots of time flushing the whole transmission and just replace it with a single extraction and filling.
thanks for all the support
