78 SN wiring harness
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=1367
Printed Date: November-21-2024 at 11:48am
Topic: 78 SN wiring harness
Posted By: scomer
Subject: 78 SN wiring harness
Date Posted: March-22-2005 at 9:56pm
does anyone have any leads or suggestions about finding a complete wiring harness for my 78 ski nautique. It has the 351 commander engine. Mine is dried and brittle I would like to have both sections(engine and boat)
------------- SCOMER
Posted By: mrese
Date Posted: March-23-2005 at 2:17am
It says it's a late 70s......
http://www.skiboathelp.com/tech/colorcode.html
Posted By: nates78ski
Date Posted: March-23-2005 at 10:52am
If you have the old harness as a pattern you can make a new one. In fact if you make a new one you can custom fit each wire to each component for a better finished look. The only problem you will have is the engine to harness connection. I use a terminal block instead of a plug(more reliable). Also to terminate the ends use non-insulated terminals & black shrink tubing to replicate the orignal look. I am in the process of doing one right now. If you need any other info let me know.
------------- Nathan http://correctcraftfan.com/diaries/details.asp?ID=1463&sort=&pagenum=3&yrstart=1978&yrend=1978" rel="nofollow - My '78 Ski Nautique
<a href="http://photobucket.com/Nates78ski" rel="nofoll
Posted By: 79nautique
Date Posted: March-23-2005 at 2:44pm
When I upgraded the alternator on my '79 I was able to get a new harness from skidim for the engine and it was an exact match to the factory harness. You might try a regional C.C. dealer for the other harness.
Posted By: scomer
Date Posted: March-27-2005 at 10:52pm
Thanks for the ideas, I think I will replace the harness with one one that i make from scratch using my old one as a pattern. And yes i will get the individual colors and heat shrink to make it look factory along with try to locate an eight pin connector.
