Sinking, HELP!!!
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=13835
Printed Date: November-17-2024 at 4:42pm
Topic: Sinking, HELP!!!
Posted By: tarver330
Subject: Sinking, HELP!!!
Date Posted: May-31-2009 at 1:24am
I have a 1993 Open Bow Ski and it's currently moored b/c of low water (can't use the lift) and it keeps sinking. Literally, I'll leave it for a week and it's sitting on the prop shaft on the dirt!! Terrible. The automatic bilge pump doesn't work in auto mode (it stays on).
Where can leaks be coming from? I'm going to tighten the stuffing box shaft nuts tomorrow.
Any other ideas?
I'm seriously worried about losing my beloved Nautique which I've owned since new. I hate leaving it in the water but it's either this or no skiing.
Thanks,
Mike
Posted By: Luchog
Date Posted: May-31-2009 at 1:36am
you need to adjust the packing gland at the shaft and rudder, if not replace the packings.
You could also have another place leaking like an exhaust or raw water pump hose.
http://www.correctcraftfan.com/diaries/details.asp?ID=2095" rel="nofollow - 1980 Ski Nautique
Commander 351W
Posted By: eric lavine
Date Posted: May-31-2009 at 11:04am
could also be coming from the rudder port also
Posted By: gun-driver
Date Posted: May-31-2009 at 12:05pm
My bet would be the exhaust and/or the mufflers.
Mine would take on water over night, it ended up being pin holes in the fiberglass mufflers.
Posted By: jbear
Date Posted: June-01-2009 at 1:17am
Hi Mike: Welcome. Where are you at over in Lakeland? We are in Lake Wales but I do most of my sking with backfoot100 on either Hancock or Elbur in Winter Haven.
Get some pictures on of your ride.
john
"Loud pipes save lives"
Posted By: adamt
Date Posted: June-01-2009 at 3:06am
The guy's boat is SINKING, and all you can think about is footin!?!?!?
-Adam
1973 Skier
Posted By: 81nautique
Date Posted: June-01-2009 at 10:35am
Don't want to sound like a wiseguy but might be a good time to fix that bilge pump.
Rudder packing, shaft packing, exhaust or speedo line/equalizer
Posted By: Rglover
Date Posted: June-01-2009 at 11:54am
[QUOTE=81nautique] Don't want to sound like a wiseguy but might be a good time to fix that bilge pump.
I agree.
My auto was staying on the other day and I figured out that the float switch was hung in the on position on the oil drain hose. It could be something as simple as that but if not those float switches are cheap. If the bilge pump is still working the float switch should be all you need.
Date Posted: June-01-2009 at 2:18pm
You sure that bilge pump isnt working correctly? Every auto bilge pump Ive seen runs for a short time when you turn it on, whether it needs to or not.
Posted By: kapla
Date Posted: June-01-2009 at 2:36pm
I agree!!!
look at the nuts and bolts that adjust the strut and also the rudder assy. Mine once leaked through those loose bolts. I adjustem them and added lots of sealant....
<a href="">1992 ski nautique
Posted By: Phantom2001
Date Posted: June-01-2009 at 3:35pm
We had a problem with a leak through the screw holes which attach the 3 fins to the bottom of the hull. After tightening everything suggested above without solving the problem, we let the boat fill up with a little water and then raised it in the lift. We could see the water running out all around the fins.
Posted By: kapla
Date Posted: June-02-2009 at 3:11am
gotcha...
