Oil Pan
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=1398
Printed Date: November-22-2024 at 2:43pm
Topic: Oil Pan
Posted By: Old Man Barlow
Subject: Oil Pan
Date Posted: April-01-2005 at 2:42pm
My brother just rebuilt 302 Ford for '65 Barracuda (we bought it with no engine). We're installing engine, and engine tilt looks like it will put most of oil too far back in the pan - hence up on crankshaft. Should this take a special (marine)oil pan? and where do we get one?
Many thanks. You boat freaks rule.
------------- Old Man Barlow
'65 Barracuda
Posted By: Stan C
Date Posted: April-02-2005 at 10:33pm
The oil pan on the 351W marine engine (center sump) is the same pan used on the ford econoline van, I am not sure if the 302 pan is the same. Look for a center sump 302 pan and you will be fine. Dont forget to install the correct oil pickup tube also.
Stan C
------------- Stan C
Date Posted: April-04-2005 at 12:15am
Thanks, Stan. Will call around....
'65 Barracuda
Posted By: Tim D
Date Posted: April-04-2005 at 11:46am
Most I've seen are at least 6 quart oil pans. Is your new engine reverse rotation?
------------- Tim D
Posted By: 79nautique
Date Posted: April-04-2005 at 11:51am
Keep in mind that a 302 and 351 pan are not interchangable. So be sure and get a 302 pan.
