Velvet Drive forward clutches
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=14166
Printed Date: November-17-2024 at 6:52pm
Topic: Velvet Drive forward clutches
Posted By: Blue Demon
Subject: Velvet Drive forward clutches
Date Posted: June-26-2009 at 12:05am
TRANNY WAS SLIPPING AT FIRST AND THEN FINALY LOST FORWARD DRIVE. I HAVE IT OUT AND APART. WHAT ALL SHOULD I REPLACE OTHER THAN FORWARD DRIVE GEARS?
Mason
Posted By: eric lavine
Date Posted: June-26-2009 at 12:24am
first, figure out what caused it to slip and then thats the part you want to replace
Date Posted: June-26-2009 at 12:35am
I ment to say clutches int the last post. Yes the clutches are shot. I tore an impeller and run her hot I think this is what got my clutches along with heavy loads. 13 skiers. Boy was she tired after that pull.
Mason
Date Posted: June-26-2009 at 8:55am
if they get hot, the pump is usually the first thing to go, so take a good look at that, if you can feel anything with your finger nail its bad. all the springs should be replaced
Date Posted: June-26-2009 at 9:03am
Good info. Thanks for your time I will check it today.
Mason
