Blown Hose, etc.
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=14327
Printed Date: November-17-2024 at 7:13pm
Topic: Blown Hose, etc.
Posted By: Greasy Lake
Subject: Blown Hose, etc.
Date Posted: July-07-2009 at 3:43am
Blew a hose this weekend on our 94 Nautique. Not that big of a deal. But we noticed on the other exhaust manifold where the non-blown hose connects to the muffler, that the previous owner must have used (what looks like) JB Weld to bind the hose to the muffler. Now, it has deveoped a slow leak. I can show you pictures if someone can tell me how to post a pic that is over the 500mb size limit.
A couple of questions:
1) I'd like to replace both hoses at the same time. What can I use instead of the JB Weld? I imagine that there was a crack where the hose clamps to the muffler which no amount of hose clamps could contain so they lapped a bunch of JB Weld on there to seal it up.
2) What size of Hose do I need to replace the blown one on a 5.8L PCM? I didn't measure it before I put it back in storage and its over a half hour away.
Thanks fellas and bear with me while I try to get pictures up.
Posted By: kapla
Date Posted: July-07-2009 at 7:48pm
use photobucket to upload them.. then use the code for forums use and paste it here... thereĀ“s a thread on the off topic section that its called how to post pictures with photobucket that will help you out!!!
good luck..
and welcome...
Posted By: kapla
Date Posted: July-07-2009 at 7:50pm
for the exhaust hose you need 3.5" the wire reinforced one!!
Posted By: kapla
Date Posted: July-07-2009 at 7:54pm
your muffler inlets are probably cracked..if so you can repair them using epoxy resins and fiberglass, that would be a permanent fix if done properly...
now you should worry on why did the engine backfire so hard that it blew the hose....
Actually a blew both hose and muffler a couple of times!!!! welcome to the club!!!
Date Posted: July-08-2009 at 1:20pm
Hmmm. We did have a backfire while decellerating a few weeks ago . . . I actually wasn't driving the boat when the hose blew (I know, I know) but the driver didn't mention any major backfire.
Thanks for the help. Any recommendations on the epoxy resin or good resources for the procedure would certainly be welcome.
