Bilge Pump Stopped
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=14359
Printed Date: November-17-2024 at 9:33pm
Topic: Bilge Pump Stopped
Posted By: LakeBoy
Subject: Bilge Pump Stopped
Date Posted: July-08-2009 at 1:54pm
OK, I am an idiot mechanic.
I can ususally fix stuff if I know where to start. So, help em get started:
Boat: '01 Ski Nautique
Problem: Bilge stopped working.
Symptoms: won't come on manually or automatically; I push button and the green "on" light next to the button on the dash DOES NOT come on; I hear a faint relay click when I push it.
Any suggestions would be appreciated on how to troubleshoot.
Got Foot?
Date Posted: July-08-2009 at 5:22pm
LB,
If you have a volt meter or at least a test light, first check to see if you do have power going to the pump. Trace the wires back from the pump to the terminals on the relay. It may be a bad pump. Just because you here the relay click doesn't mean you have power going to the pump. The pump may be on a different circuit (fuse) than the control circuit for the relay.
Posted By: LakeBoy
Date Posted: July-08-2009 at 5:28pm
Where is the relay/fuse located? Under the dash?
How relevant is the indicator light not coming on?
Got Foot?
Date Posted: July-08-2009 at 11:15pm
Sorry I don't know. Where is the clicking sound you're hearing? As mentioned, try to see if you can trace the wiring back from the bilge pump.
It may just be burnt out or yes it may be on the same circuit as the bilge pump (not the relay coil circuit) in which case it would indicate no power to the pump/light. Fuse? Relay contacts burnt up? In ether case, there's always a reason - bad pump pulling too much power/amps.
Posted By: 79TiqueRebuild
Date Posted: July-08-2009 at 11:29pm
In the past I have had debris caught in the impeller blade. I had to remove pump from bilge and take apart and clean it out.... Monty
Posted By: LakeBoy
Date Posted: July-09-2009 at 2:08pm
Well, I did the deal yesterday. Check the fuses, they were OK. On my firewall there is a power on/of swith with a bilge pump "on" switch setting. Also a bilge "breaker", one of the push in variety. It was popped out. (tripped) I pushed it in and I then popped the wires off the bilge and checked for power.
Got power. Popped the bilge out and the motor was tough to spin, so I figured the bilge pump is crap.
Any advice on replacing it? Mine is a Rule 500 Automatic bilge pump.
What is the deal on automatic v. non-automatic?
Got Foot?
Date Posted: July-09-2009 at 2:15pm
http://www.go2marine.com/product.do?no=70515F - $73 from Go2Marine
Might want to take Monty's advice though- according to Rule, their pumps offer a "Snap-off strainer for easy cleaning". Might be worth a try before replacing.
Posted By: LakeBoy
Date Posted: July-09-2009 at 6:49pm
The strainer area was pretty clean. I think the motor siezed up. May have run dry or something. I went to West Marine and the Rule Automatic 500 GPH was 60 bucks. Not bad but it was a 3-wire pump and mine is a 2-wire. Much less an electrician than a mechanic, I opted for the 2-wire, non-auto model at 27 bucks. I trailer my boat and could not see getting into a re-wire project for a bilge that is used on occaision or emergencies. Plus the new pump snaps right onto the base that is already installed.
I let you know how it comes out.
Got Foot?
Posted By: Rick
Date Posted: July-10-2009 at 6:29pm
The automatic pump when power is applied runs for 2 secs every few minutes. If it senses a current draw (ie water making the impeller harder to turn) it will run for a specified time then shut off and go to the quick on off mode until if feels water again. The manual pump needs a float switch to activate the pump.I've never seen a three wire I would contact Rule and ask. Ypu really want an automatic though or you will have to install a float switch unless you want it to run all the time.
http://www.correctcraftfan.com/diaries/details.asp?ID=250&yrstart=1996&yrend=2000%20" rel="nofollow - 2000 Ski
Posted By: LakeBoy
Date Posted: July-10-2009 at 7:28pm
Rick, thanks for that. I opted out of the automatic. It was 60 bucks instead of 30 bucks, and I didn't want to get into a rewire project. I have no need for an automatic per se. More of a luxury. Got the manual installed last night. If I need the bilge, I hit the switch. I get very little water in my bilge, mostly want it for emergencies like a hole in my hull. I trailer the boat, and leave it in the water when I camp at my ski club. After 4 days in the lake, I am lucky if there is 3/4" of water in the bilge.
This way I am set. If it annoys me somehow, I can spring for the auto and the rewire.
Thanks guys for the tips!
Got Foot?
Date Posted: July-10-2009 at 10:22pm
Glad you are back on the water. Keep the footing videos coming.
I would like to attempt some day.... Monty
Posted By: LakeBoy
Date Posted: July-13-2009 at 2:56pm
Thanks Monty. Went footing yesterday, no video, just me and the wife. You should try it Monty. Find someone who has a boom and try this:
http://www.youtube.com/watch?v=L5xaeeQzQpc&feature=channel_page - First Time Footer
This is my friends first attempt ever.
Got Foot?
Date Posted: July-14-2009 at 12:52am
Wow That looks like so much fun! I will have to try it. Thanks
Posted By: BretC
Date Posted: August-08-2009 at 1:29am
Guys - Because I feared the original bilge pump might fail, or I might forget to leave it on I installed a second bilge pump. A "Whale" brand of pump. http://www.whalepumps.com/documents/brochure/SUPERSUB__SMART_650.pdf
I added a second thru hull fitting and changed the original thru hull fitting to stainless to match the new one. It was a pain to run the bilge tubing but was able to snake it through the access tube. The new Whale is wired direct to the battery so it does not have a manual over ride now. It is always hot and ready to go no matter what position the dash switches are in. The best part of this back up pump is there is NO mechanical float switch to mess up! It has a water sensor on it. Also, because it is a horizontal pump rather than a vertical pump it fits neatly under the engine. Lastly, it kicks out a steam of water about 5 times bigger than the original. If you add a pump or replace your original you should also consider replacing the cheap ribbed tubing with smooth wall bilge pump tubing. It offers much less resistance. I considered this installation just cheap insurance.
Hope this helps someone.
1990 Correct Craft
Bret C
Neodesha, KS
