Ski Pole removale
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=14429
Printed Date: November-17-2024 at 7:17pm
Topic: Ski Pole removale
Posted By: Fook_U
Subject: Ski Pole removale
Date Posted: July-13-2009 at 12:28am
How can I remove the electrolysis that is around the base of the pole? I'm tring to remove the pole, but I cannot lift the pole or twist it to remove it from the base plate.
http://www.correctcraftfan.com/diaries/details.asp?ID=1366 - Andy's '87 2001
Posted By: hasbeenskier
Date Posted: July-13-2009 at 11:31am
Heat...(Acetylene Torch) Be careful
hasbeenskier
Posted By: dwcar
Date Posted: July-13-2009 at 11:27pm
Andy,
If you have the engine out I suggest that you soak it in penitrating fluid for a few days. Then take a pipe wrench on the base below the floor. It will skuff it up a bit but it will be down under the floor. There was a bolt on my 83. I dont know if there is one on your 87.
you might also need a cheater pipe.
83Ski
Posted By: Fook_U
Date Posted: July-13-2009 at 11:29pm
Thanks, I will try that.
Posted By: ryanowen
Date Posted: July-14-2009 at 12:43pm
Same bolt on my 88. I had to tap it back out and swear a lot.
http://www.correctcraftfan.com/diaries/details.asp?ID=3284 - 1988 Ski Nautique
Posted By: Hollywood
Date Posted: July-14-2009 at 12:58pm
Fook, did you have the ring/finger top or the ball? Either way, there is a bolt through the bottom. I'm guessing you had the ring/finger if you're having such difficulties.
Date Posted: July-14-2009 at 1:26pm
80-87 ring/finger pylon base (the one that is hard to remove). Otherwise the 87+ (some 87s had the ring/finger, later builds got the ball top) ball top is just the 2.5" straight pylon to the floor with a larger cup around it, and a bolt.
Posted By: Fook_U
Date Posted: July-14-2009 at 1:34pm
Date Posted: July-14-2009 at 1:57pm
Lucky you, what's the problem then? Get that bolt out (7/16" ?) and pull it right up. I took ours out of the 88 with the engine and floor still in!
Posted By: BuffaloBFN
Date Posted: July-14-2009 at 2:01pm
Maybe the bolt or the base is glassed in? I'll look for a pic of the base.
http://correctcraftfan.com/diaries/details.asp?ID=2331&sort=&pagenum=12&yrstart=1986&yrend=1990" rel="nofollow - 1988 BFN-sold
Date Posted: July-14-2009 at 2:04pm
It's just a socket pinned with a bolt and I think HW even got the size.
