1978 - Strut Repair
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=1456
Printed Date: January-15-2025 at 5:44pm
Topic: 1978 - Strut Repair
Posted By: Guests
Subject: 1978 - Strut Repair
Date Posted: April-14-2005 at 7:32pm
I am replacing/repairing the strut of my 1978 Correct Craft Ski Nautique.
Does anybody have the factory measurements / dimensions that I could get my hands on?
Thanks in advance
Posted By: swamp demon
Date Posted: April-15-2005 at 1:07pm
You might call bruce at mid-west cc in angola,Indiana. He is very helpfull.
What excatly are you trying to do?
Posted By: nates78ski
Date Posted: April-17-2005 at 4:07pm
If you need a replacement strut Buck-Algonquin makes has replacements. If the strut is bent it may not be wise to straighten it. Do you need the strut dimensions or location dimensions????
If have a source for new struts.
Nathan
http://correctcraftfan.com/diaries/details.asp?ID=1463&sort=&pagenum=3&yrstart=1978&yrend=1978" rel="nofollow - My '78 Ski Nautique
<a href="http://photobucket.com/Nates78ski" rel="nofoll
Posted By: Guests
Date Posted: April-20-2005 at 9:11am
My 01 SAN strut may had little blend due to hit on stone,so the shaft feel thigh after change prop and shaft ,if you would post some information about change strut,how? skills and measuement,I'll very appreciate that.
Posted By: Guests
Date Posted: April-21-2005 at 8:44pm
Not too much skill required. Just remove the prop, loose the four bolts from the strut, let the strut swing down on the shaft & slide off. To install reverse procedure & make sure you bed the strut & bolts with bedding compound.
