windshield frame help
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=14566
Printed Date: November-17-2024 at 8:38pm
Topic: windshield frame help
Posted By: mjdean
Subject: windshield frame help
Date Posted: July-21-2009 at 11:49pm
My '84 Southwind windshield frame vibrates the screws out and it comes apart under way. Any suggestions? I am thinking of larger diameter screws is the only solution.
Thanks,
Micah
------------- Micah Dean
Posted By: drduck
Date Posted: July-22-2009 at 12:08am
Maybe thru bolting with locknuts on the underside would be the answer.....make sure to use fender washers to help spread the load.
------------- What were they thinking!!??
Posted By: drduck
Date Posted: July-22-2009 at 12:12am
Ok Now i have rethought the possiblities.are the screws that hold the frame together coming undone? If so try locktite thread lock on those. If the frame is coming loose from the boat use the thrubolt method.
Of course, that Just my opinion.
Posted By: dwcar
Date Posted: July-22-2009 at 12:31am
you might try a little J-B weld in the screw hole. You can buy new stainless screws with black heads at Lowes.
------------- 83Ski
Posted By: BuffaloBFN
Date Posted: July-22-2009 at 10:52am
Maybe look into the source of the vibration first?
Posted By: mjdean
Date Posted: July-22-2009 at 1:20pm
Thanks for all the help. The vibration is just from normal operation, shouldn't have called it a vibration, none the less, the windshield frame comes loose. I'll try the thread locker and larger sheet metal screws.
