PCM 1.23:1 Wanted
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=15223
Printed Date: November-19-2024 at 4:25am
Topic: PCM 1.23:1 Wanted
Posted By: Naughty93
Subject: PCM 1.23:1 Wanted
Date Posted: September-08-2009 at 4:34pm
Someone threw a banana peel in my tranny! Now I need a PCM 1.23:1. Any help out there?
Posted By: rookie
Date Posted: September-09-2009 at 2:04am
i have what looks like a complete rebuilt tranny in the bf i'm parting out let me check the numbers and i will shoot you a line in a few mins.
we took the motor out and it has never been cranked all new stuff and the pump on the trans looks equally good.
rookie
------------- do it right the first time...
Posted By: rookie
Date Posted: September-09-2009 at 2:09am
sorry pcm 40-1
1.0/1.0
Date Posted: September-09-2009 at 1:54pm
Posted By: eric lavine
Date Posted: September-09-2009 at 1:55pm
what is wrong with yours?
Date Posted: September-11-2009 at 5:10pm
Well, initially when I changed the oil this summer it looked really watery. I went ahead and flushed it about 3 times, topped it off & ran it. Felt fine except that it began losing oil(about a qt each weekend). I couldn't really tell from where. Last weekend I had a loaded boat & of course without checking the oil at the start I felt it gradually slip until about 25 mins. into it it lost all torque. I trolled it back at about 3mph and added 2 whole friggin qts. Runs fine now. I'm sure I hacked the plates running it low.
Posted By: GottaSki
Date Posted: September-11-2009 at 5:22pm
Paging Dr. Lavine...
River Rat to Mole
Date Posted: September-11-2009 at 6:55pm
Must be on post call
Date Posted: September-12-2009 at 11:23am
all i can say is they cant take low oil like a Velvet, once you glaze the plates from slippage, they lose thier ability to hold.....keep an eye on it.
Date Posted: September-14-2009 at 1:11pm
Gotcha, well hopefully it holds for just a few more runs. I see gray clouds up above
Date Posted: September-14-2009 at 8:20pm
Another thing, has anyone tried using any additives as a temp. band-aid? Stuff like Lucas trans additive or the stuff made by 'Gunk'?
Posted By: Fl Inboards
Date Posted: September-14-2009 at 9:27pm
I have two Core 123:1 PCM here in the shop I will be more than happy to ship one to Eric for rebuild. You can work out the rebuild with him. one is stuck in forward the other just leaks and has a high amount of hours on it but still operates correctly and has good preasure. $300.00 for either plus shipping.
------------- Hobby Boats can be expensive when the hobbyist is limited on their own skill and expertise.
Date Posted: September-14-2009 at 11:03pm
Naughty93 wrote:
Another thing, has anyone tried using any additives as a temp. band-aid? Stuff like Lucas trans additive or the stuff made by 'Gunk'? |
Well, you can put a additive in the trans but that's only if you want to give it a quicker kiss of death.
You need to understand that the marine automatic trans really has very little in common with the automotive trans. Both simply use the same fluid. The marine trans does not have the torque converter in it where these additives may help by changing the viscosity and modifies the friction of the fluid. A marine trans simply uses a hydraulic pump to apply pressure on the clutch packs (not a torque converter) which engage/couple the engine to the prop shaft. What used to be done manually with the big shift lever through the floor is now simply done hydraulically.
Posted By: JoeinNY
Date Posted: September-15-2009 at 1:06am
Did you ever replace the leaking transmission cooler, or whatever it is that is eating quarts of transmission fluid at a time?
1967 Mustang 302 "Decoy"
Date Posted: September-15-2009 at 10:19am
Oh, I can tell the additive tranny's, twice the price to rebuild, they swell the rubber up and cause real problems, dont use them
Date Posted: September-15-2009 at 7:56pm
Thanks for the info Eric! No additives it is...phew! I have not changed the cooler either. I really don't see oil leaking from it, more oil coming from the bottom of the tranny, closer to the output flange. One more weekend & it's going on a trip to Sir Eric.
Posted By: QUEBEC
Date Posted: September-19-2009 at 11:22am
CHANGE YOUR TRANS COOLER IT'S LEAKING INSIDE AND THE FLUID GOING OUT THE EXHAUST. IF THERE NO FLUID IN THE BOAT IT'S GOING OUT THE BACK INTO THE WATER.
Date Posted: October-08-2009 at 6:54pm
It's def. not leaking back into the exhaust. The fluid ends up back in the bilge with a strawberry shake looking color. 2 weekends ago I took it out for the last time this season, topped it off & she hauled 2 adults on a tube with no slips at all. The tranny works great just leaks like crazy. The boat only has 405 hours.
Date Posted: October-09-2009 at 11:38am
Naughty93 wrote:
I took it out for the last time this season, topped it off & she hauled 2 adults on a tube with no slips at all. |
No name.
Well, we now know the real problem!! Tubing!!! Just kidding here but do try something with a higher skill level like skiing or boarding.
Regarding the water in the trans, I think you got a little side tracted here about the oil comming out the exhaust. That's real hard to detect plus it's not the concern. With a leak in the cooler, the concern is the water getting to the trans. The best way to check out the cooler is to pressure test it to make sure there isn't a leak between the oil and water circuits.
The oil in the bilge isn't related to the cooler. it's probably the front seal and there is a reason for it to leak.
Keep a eye on the color of your trans fluid and do a pressure check on the cooler.
Date Posted: October-09-2009 at 1:35pm
That sounds a bit more plausible. Cooler leak/water into the tranny/overflowing the tranny causing it to blow the seals thus the frothy strawberry shake in the bilge. Does that sound about right?
Oh, & sorry, our skill level on a board/ski are about those of a 9 mo. old wearing socks on a linoleum floor Just kidding, it was hangover Sunday, less coordination!
Date Posted: October-09-2009 at 8:24pm
If water is going in at the cooler, then oil is going out the exhaust too so the trans isn't being overfilled. I'm sur Eric will be alone and will comment but the front seal issue isn't due to the trans overflowing but rather a sloppy pump. This allows oil to flow around the pump and pressurizes the area at the front shaft seal. 405 hours are on the trans! Still, it may be time for a rebuild.
