gas shooting out top of carb
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=1551
Printed Date: September-27-2024 at 11:21am
Topic: gas shooting out top of carb
Posted By: Guests
Subject: gas shooting out top of carb
Date Posted: April-27-2005 at 9:44pm
any suggestions? I am engine ignorant
engine not starting....gas shooting out of the top of the carb like a foutain about two feet high.....
stuck valves?
all valves seem to be moving correctly...if that means anything...
I would definitely appreciate anyone's comments!!
Posted By: Guests
Date Posted: April-28-2005 at 5:31am
Did you have replace your starter or have it rebuit? It could be cranking the engine the wrong direction.
Posted By: 73skier
Date Posted: April-28-2005 at 6:40pm
my 73 did the same thing got the wrong starter so it blew gas out just like that and wouldn't start.can also catch fire from piston firing thru the carb.
Posted By: Guests
Date Posted: April-28-2005 at 9:30pm
excellent call!!!
yes, I did just replace the starter that was ordered by a mechanic..... that could be it!! How do I differentiate between the right and wrong starter?
Have I potentially caused long term damage to anything?
Posted By: Guests
Date Posted: April-29-2005 at 3:02am
There are two ways to tell on the starter. easiest is to put it on a test stand at any auto parts store and watch the rotation, the second is to look at the relief cut of the gear tooth, it will be on the trailing edge or root of the tooth and provides clearnce as the flywheel teeth mess with the cranking motor's gear teeth.
