Fuel Filter / Separator question ...
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=15617
Printed Date: November-17-2024 at 6:00am
Topic: Fuel Filter / Separator question ...
Posted By: damonwells
Subject: Fuel Filter / Separator question ...
Date Posted: October-17-2009 at 6:57pm
1990 SN FORD 351 PMC
My current remote mounted fuel filter separator is a FRAM, FCS1136M I believe. Mounted to a bracket, which is tapped into the aluminum stringer, engine compartment forward port side. It has an orange top and an 8" black housing that spins on & off, with the FRAM CCS1136 long filter inside.
The folks at SKIDIM talked me into a new type spin-on canister & mount. It is a Sierra (Teleflex) 18-7852-1 with a #18-7845 Separating Filter that spins on. This mount will require drilling new holes to the existing bracket or stringer. All the fittings are the same.
I didn't realize the mounting of the new Sierra housing (bolts from side) would be different than the older Fram (bolts from top). Before I do the new install, I'm wondering why SKIDIM recommended this change, I'll call them on Monday ... but will this change/upgrade be worth the effort ?
And, when changing fuel filters, should I fill the new canister with clean fuel before assembly and do I need to bleed air after installing new filter, and if so, how is this done ?
thanks, cheers, John
Posted By: Fl Inboards
Date Posted: October-17-2009 at 7:21pm
Why did you change?
The Fram is a supurb filter a bit bulky but works great none the less.
Wix also makes a replacment cartrige (# 33436) for the fram Filter seperator.
------------- Hobby Boats can be expensive when the hobbyist is limited on their own skill and expertise.
Posted By: DrCC
Date Posted: October-17-2009 at 10:27pm
Spin on! Way less hassle.
No need to pre-fill.
Posted By: chrisawalker45
Date Posted: October-19-2009 at 9:31am
i have done exactly the same upgrade to my 196 1991. i had the same filter and changed to the spin on one. I removed the old filter bracket, cut it about 2 inches up from the 90degree bend, filed off the edges, drilled 2 new holes for the new spin on bracket to bolt onto then bolted it on. Fairly easy, just modify your existing bracket!
Date Posted: October-19-2009 at 1:44pm
Thanks Chris ... why did you use / modify the bracket, instead of abandoning the bracket entirely, and drill/tap the black mounting bracket/housing that comes with the Sierra directly to the stringer ? This is what I am thinking ...
cheers, John
Date Posted: October-21-2009 at 10:07am
hi john, just so that i could use the existing holes already in the stringer, and not having to drill new holes and fill the old ones, also the lower jo go with it, the harder it will make it to change.
Chris
Posted By: BoyceByerly
Date Posted: May-23-2015 at 11:22pm
I got mine off on my '79 Mustang. It ended up being a Fram 1110CL, not the 1136. From the earlier discussion, I got the impression that fuel filters come off just like an oil filter. Mine looks like that, but it's not the case. You have to undo a bolt that holds it on, which is on the top of the filter unit. I wasted a lot of time grunting away at the thing with an oil filter wrench. Just wanted to put that out there, in case somebody else is wasting time trying to get it off like that.
------------- Boyce Byerly Owner of a '79 Mustang
