Tranny oil leak
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=15671
Printed Date: November-18-2024 at 3:45am
Topic: Tranny oil leak
Posted By: Chopper
Subject: Tranny oil leak
Date Posted: October-23-2009 at 9:59pm
I have an oil leak in the 89. symptoms are that it appears to be comming from the input shaft seal & leaking out into the bilge.
It's 1.23:1 tranny
Researching here it seems that the tranny might be over pressurizing & forcing fluid past the seal. Is this the pump.?
The delema I have is that there is no local CC dealer to me, and that my local ski boat agent isn't interested in looking at it.
Is this something that I can repair myself or can I take it to an auto tranny specialist.?
http://www.correctcraftfan.com/diaries/details.asp?ID=1540&sort=&pagenum=2&yrstart=1996&yrend=2000 - 98 Ski
Date Posted: October-23-2009 at 10:44pm
Andrew,
I know you're pretty handy so why don't you try to let Eric walk you through the rebuild. I'm sure he'll see the post and comment shortly - or rather tomorrow as he's probably at Rico's right now - It's Friday!!
Don't take it to a automotive trans shop. They won't know what they were looking at!! The only thing in common between a auto trans ans a marine is the fluid in them.
Posted By: Chopper
Date Posted: October-23-2009 at 10:59pm
Thanks Pete,
Yes I was a little worried that an auto trans shop might not know too much about them, but if I can be stepped through it I'm sure I will be able to effect the repair.
My tranny cooler does have a small water leak at the outer seam. It's only a slight drip. This just needs to br re soldered. This wouldn't be contributing to the problem.?
Date Posted: October-24-2009 at 9:34am
Originally posted by Chopper Chopper wrote:
Thanks Pete,
It shouldn't as long as the leak is external and small. Does your trans fluid look ok? No water? I'd worry about the RWP sucking air at the leak more. Any cooling issues with the engine?
Soldering them up can be a PITA because the copper at the leak has oxidized. Sometimes you need to pull the whole end off to get it cleaned up enough to take the solder. Try a acid flux first and of course make sure it washed up real good to get rid of any residual acid!!
Posted By: eric lavine
Date Posted: October-24-2009 at 10:45am
on the 1.23"s the front shafts will pit and cause a seal leak, highly unlikely the pump is bad. start with a seal and emory cloth the shaft,and install new seal
Posted By: Chopper
Date Posted: October-24-2009 at 11:36am
So it could just be the seal.?
I will pull the seal, emory the input shaft & replace the seal. It that correct.?
Posted By: Chopper
Date Posted: October-26-2009 at 9:37am
What is the best way to drain the oil.?
Is there a drain plug.?
Date Posted: October-26-2009 at 10:11am
pump it out Chopper, try a seal first and order a damper also
Posted By: Chopper
Date Posted: October-26-2009 at 7:57pm
Eric do you supply these bits or do I use SkiDim or similar.?
Date Posted: October-26-2009 at 10:45pm
one of the above
Posted By: Chopper
Date Posted: November-03-2009 at 1:03am
Forgive me as I have sinned.!
I'm just going to get my local "cough" Malibu "cough" dealer fix it. I spoke with them about it and they mentioned that they see the same issue with their ZF transmissions on the mals. Seemed to think it would be a pretty straight forward / easy fix.
I just don't have the time at the moment with current work commitments. I have a buyer keen on buying the 89 & I'm still trying to finish off the new trailer for it.
