Various parts needed for 1991 Ski Nautique
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=15677
Printed Date: November-19-2024 at 2:32am
Topic: Various parts needed for 1991 Ski Nautique
Posted By: Chopper
Subject: Various parts needed for 1991 Ski Nautique
Date Posted: October-24-2009 at 11:16pm
Hi Guys,
I'm looking for the following bits & pieces for a 1991 Ski Nautique.
1. Carby
2. Alternator
3. Throttle hand control
4. Dash pod & gauges
5. Steering wheel
6. Raw water pump
If you have any of the above, please let me know.
Cheers.
http://www.correctcraftfan.com/diaries/details.asp?ID=1540&sort=&pagenum=2&yrstart=1996&yrend=2000 - 98 Ski
Posted By: 91nautique
Date Posted: October-24-2009 at 11:39pm
Chopper,
I have a carb,alt and sherwood raw water pump,located in Perth.
Have a heap of other spares as well.
Posted By: behindpropeller
Date Posted: October-24-2009 at 11:50pm
Originally posted by Chopper Chopper wrote:
Hi Guys,
Buy this new. You don't want an old junk one with no safety interlock.
Posted By: Chopper
Date Posted: October-25-2009 at 2:07am
Originally posted by 91nautique 91nautique wrote:
Chopper,
Hey mate,
Can you please send me an email with asking prices and details on other spares.? maybe some pics.?
munstr2001@yahoo.com.au
Cheers.
Posted By: lewy2001
Date Posted: October-25-2009 at 10:53am
Chopper it might be worth replacing the Protec ignition while you are at it. I had forgot about 91Nautique he loaded a container up with all sorts of bits and pieces.
91 nice to hear from you again.
Posted By: 82 Nautique 1
Date Posted: October-26-2009 at 1:12am
Hey dude is this the Boat from California? I was bidding on the boat as well. Where do you live ? Have you picked up the boat yet ?
I was really interested in the boat. If you can email me Pic's of the boat that would be cool.
Dennis
DHBWG@MCHSI.COM
Original Owner " Dennis"
http://www.correctcraftfan.com/diaries/details.asp?ID=4855" rel="nofollow - 1982 Nautique
Date Posted: October-26-2009 at 6:48am
How's it going Mark - enjoy your US trip?
Chopper- When I imported my boat in the late 90's I actually brought two and junked one over there and filled my boat up with everything off the junked boat and anything else I could lay my hands on..
Whats I have left (from memory) -suit windsor.
1.23.1 trans & bellhousing
2 sets of engine mounts & brackets
carb, spacer & flame arrestor
alt & adj arm
timing cover
sherwood pump & mounting bracket
pulleys
starter
complete open cooling system (PCM)
partial closed cooling system (PCM)
complete closed cooling system (mercruiser)
marine electronic dizzy (mercruiser)
p bracket
shaft
prop
skipole
some dash switches
By the time you pay for transport and recon'ing the carb and pump it might be better to grab some new ones, if you need the carb spacer,flame arrestor, alt & adjusting arm and mount for the sherwood pump, you can have them-you owe me a beer, let me know and I will go down to where the gear is stored and sort through it.
Melbourne Carb's sells a recon 600 vac sec marine carb for about 300 bucks-have a look here
http://stores.shop.ebay.com.au/Melb-Carbs-and-Injectors-pty-ltd__W0QQ_armrsZ1
As for the pump- tried Albury performance?
Posted By: Chopper
Date Posted: October-27-2009 at 6:46am
alt & adj arm
timing cover
pulleys
starter
p bracket
shaft
prop
skipole
some dash switches
Mate the pump mount is still on the block, but pump is missing.
From your list of bits & pieces I would be nterested in the following:
carb & arrestor - spacer is still on the manifold.
Alternator & bracket.
Sherwood RWP (and the top piece of PCM hose if you have any)
I don't know if the starter is there or not?
Do you happen to have ignition leads.? Even if they are no good it will help me with lengths of new ones.
I'd probably owe you more than a beer for all that.!
what are your contact details.?
Posted By: Chopper
Date Posted: October-27-2009 at 6:56am
Dennis
DHBWG@MCHSI.COM
Hey Dennis. Sorry buddy yes that's the one. If it makes you feel better I only put one bid on it before I went to bed & woke up to a nice supprise. You nearly had me though.!!!
It gets picked up tomowwow (Tuesday) for the start of it's long journey back to Australia.
Date Posted: October-29-2009 at 12:00am
Chopper,
Do you need the bracket that bolts the alt to the housing as well as the adjuster arm (looks like yours is missing) I have that as well.
No hoses or leads, Enzed sells wire reinforced flexible hose
http://www.enzed.com.au/centres.php
The starter motors are the same as XD falcon.
Looking at the pic of the engine it appear's the steel fuel line from the pump to the carb has gone awol as well.
PM sent
Posted By: Chopper
Date Posted: November-10-2009 at 10:08am
Hi Dan,
Mate I missed your reply here. I really don't know exactly what's missing. If it looks missing, it probably is.
I probably need to wait until it gets here to be sure.
I'll give you a call to discuss the parts.
Here's another motor pic.
Posted By: eric lavine
Date Posted: November-15-2009 at 12:21pm
first thing you do when you get that beauty is turn her over by hand. you can always tell the engines that got a little rain water down them, the piston will be halfway up and the cylinder will be pitted and at times wont turn over by hand, I hope this isnt the case...hopefully the cover was down the entire time and they didnt forget to lower it at one point...and it may be worth turning it in case the party responsible for stealing the boat didnt drop one of the carb nuts down the throat
Date Posted: November-15-2009 at 12:23pm
one thing i do notice is they took the steel line with the carb and disconnected it at the pump...why not at the carb?
Posted By: Chopper
Date Posted: November-16-2009 at 6:00am
Yep that's the first thing that will be done for sure.
The cover is down in most of the other pics I have, so hopefully it's all good. I am a little worried about a carb nut or similar too, so we'll see how it goes.
I'm quietly hopefull that there might be a couple of parts sitting in the bilge.
Wherever this thing was when it was "stolen" they sure seemed to have some time to remove parts carefully.
