transmission problems
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=15781
Printed Date: November-18-2024 at 2:25am
Topic: transmission problems
Posted By: skister72
Subject: transmission problems
Date Posted: November-09-2009 at 8:38pm
Okay I just bought my 75 in July and my its been running alright, but I have noticed that the transmission seems to hesitate. At first the it was shifting fine then it seemed like I was pushing the throttle more and more. Once it engages and i start to accelerate it cuts out and then reengages. I'm not sure what to look at if anyone can help that would be awesome. Thanks
1975 ski nautique
Posted By: form&function
Date Posted: November-09-2009 at 8:55pm
What did the fluid look like?Was it full when you checked it?
Date Posted: November-09-2009 at 8:57pm
As much as i can recall it was red and i do believe it was full.
1975 ski nautique
Date Posted: November-09-2009 at 9:05pm
Disconnect the shifting cable and put it in gear by hand.If it goes in fine your cable\shifter is the problem.If not theres a tranny guy on this forum that treats us right.
Posted By: Hollywood
Date Posted: November-09-2009 at 9:15pm
Are you SURE it was full? Describe the process you used to check it.
Date Posted: November-09-2009 at 9:59pm
Josh,
In the sites reference section, there is a sub section with manuals. One of them is for the Velvet drive. Check out page 22 for the procedure to check the fluid level. Heres a link for you: http://www.correctcraftfan.com/Downloads/Velvet_Service_Manual.pdf - Velvet drive manual
Welcome to CCfan. Tell us more about the boat and of course we love pictures. Stringers in good shape or have they been replaced?
Date Posted: November-10-2009 at 12:54am
the well the dipstick read full and i was in the water and i had let the engine warm up. thats how i checked it. any other way im supposed to check it?
1975 ski nautique
Date Posted: November-10-2009 at 12:56am
i have disconnected the cable before tho i was not in the water. it seemed to go into gear fine but i am new to these type of boats and these transmissions.
1975 ski nautique
Date Posted: November-10-2009 at 1:47am
The tranny in you boat is very simple.A plunger connected to the shift lever directs fluid to the clutch pack.
Could you describe your problem a little better?From what I read it sounds like a delay going into gear and slipping under load?
Date Posted: November-10-2009 at 4:06am
That's sounds like what it does. But it only does it for a second and then reengages. Sometimes you can ease into the throttle and it doesn't do it but most of the time it does. Since I bought it I have not repacked the drive shaft could that have anything to do with it?
1975 ski nautique
Date Posted: November-10-2009 at 9:11am
Josh,
Disconnect the shift cable at the trans as recommended but with it in the water running. Then try manually shifting the trans and see what happens. This will tell you if there is a cable adjustment problem. Without the engine running, shifting the trans is simply moving a valve. It's not like a manual trans where you are physically moving a shift fork/clutch.
No, repacking the shaft stuffing box shouldn't have a effect unless you have it so tight it binds the shaft but you would only notice that at low speeds. Is the stuffing box running hot?
Did you find the Velvet drive manual and look at it for checking the fluid level? I ask because you asked about the procedure again. BTW, the problem doesn't sound like it's caused by a low oil level.
Posted By: eric lavine
Date Posted: November-10-2009 at 10:18am
does the tach shoot up under heavy power? it will surge if it is slipping, it should not delay in any way, when you shift the lever it should go right into gear. if you have to rev the engine to make it go into gear then there is an internal leak
Date Posted: November-10-2009 at 1:29pm
the stuffing box isnt hot actually i need to redo it its leaking more than it should. i did find the manual thanks.
the tach doesnt shoot up. maybe this will help...like when im docking and using reverse i go from neutral to reverse and it seems like it just doesnt go into gear right away i slowly push the throttle more the motor is not reving up just idles till it finally catches then it takes off. its kinda the same with going into forward. from a dead stop ill push the throttle forward just to where it should be at idle speed and leave it and it will take a sec and it will put itself into gear. does that explain it better. -Josh
1975 ski nautique
Date Posted: November-10-2009 at 1:39pm
Josh,
Unless Eric has another idea, it sounds like you need to take a look at the helm to trans cable adjustment. When you move the helm to ether the forward and reverse position (without advancing it to give the engine gas) make sure the shift lever at the trans is moving to the respective forward or reverse position. When the helm is in neutral, the same is true for the neutral position on the trans. With wear at the pivot points on the trans and helm the shifting can get sloppy. Cables can stretch too but that will only throw off the adjustment in one direction (forward).
