Heater Instal ?'s
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=15787
Printed Date: November-18-2024 at 2:34am
Topic: Heater Instal ?'s
Posted By: TX Foilhead
Subject: Heater Instal ?'s
Date Posted: November-10-2009 at 3:28am
I'm installing a heater and doing some electrical upgrades this weekend and have some questions, it is going into a 93 Excel O/B (V Drive).
Should I run the heater hose along with the steering, throttle and wiring in the floor, or should it go under the gunnels? I'm concerned I might be putting too many things in the floor, and will have issues when I need to pull one of them out in the future.
Would it be OK to put some air line quick connects in the heater hose so that I could blow it out with an air tank real quick? We use the boat year round, at least every other week. In the past I have used the ball valves that SKIDIM sells, and kept a block heater on the oil pan that runs on a thermostat. This boat stays on a lift and it is very rare to see the water get below 50 and the air temp to remain below freezing for 24 hrs. I'm thinking about using one of the bilge heaters and leaving the the water in the block to cut down on the rust scale. I'm thinking the quick couplings might be nice to hook to an air tank for blowing out the heater rather than trusting gravity to drain the hoses.
I'm going to run an extra positive and ground to the dash, it looks like the main ground from the motor goes to the Tach 1st and the positive goes to the ignition breaker. Where to you hook them up in the back?
Last, is it OK to drill into the floor to secure the heater core? I think I have enough space to mount it in the bow under the playpen, but the only way to secure it would be with L brackets screwed to the floor.
Date Posted: November-10-2009 at 11:41am
Ive never seen the heater hoses routed anywhere but through the same tube as the steering cable, etc- but Ive always worked on direct drives. Do whatever makes the most sense! Ive got quick disconnects on my lines for the same purpose youre talking about- you can get them from Lowes (garden hose fittings).
For the electrical connections at the engine, grab the positive from the protected side of the breaker. Get the negative from the ground bolt- there should be one close to the wire harness (mine is on the intake manifold).
Im not sure of any other way to secure the core than screwing it down. Just make sure you seal the holes up good to prevent water from getting in there.
Posted By: quinner
Date Posted: November-10-2009 at 1:28pm
Either way you do the core connections I would not use compressed air to purge the lines unless it's very low pressure, have always used lung pressure to clear mine without issue.
Date Posted: November-11-2009 at 11:50pm
Alright it is here, thanks for answering my questions, now I have a more. There is nothing like having new toys in your hand a realizing your plan doesn't work.
I never realized that the hot tubes come in a foot long plastic tube so now my idea of where 2 of the 3 vents would be mounted is either out the window, or will require some fabrication. The regular vent will mount under the dash to blow on the drivers feet. I was going to have one hot tube on each side of the observers seat, but I wasn't figuring they would be a foot long. Where did the factory mount the heater outlets on these boats? I'm trying to talk myself out of drilling large holes behind the windshield, so if anybody has any other ideas that could be patched up easily at I later date I would love to hear them.
Posted By: behindpropeller
Date Posted: November-12-2009 at 12:33am
I never realized that the hot tubes come in a foot long plastic tube so now my idea of where 2 of the 3 vents would be mounted is either out the window, or will require some fabrication. The regular vent will mount under the dash to blow on the drivers feet. I was going to have one hot tube on each side of the observers seat, but I wasn't figuring they would be a foot long. Where did the factory mount the heater outlets on these boats? I'm trying to talk myself out of drilling large holes behind the windshield, so if anybody has any other ideas that could be patched up easily at I later date I would love to hear them. |
Since you are only going to need the heater for four months a year I would not drill any holes. Just mount the heater in a place that you can get the heater hoses to both seats and take them off when not in use.
Tim
Date Posted: November-12-2009 at 2:41am
That's a possibility, I hope I can leave it in there though. We could use it 6 or 7 months out of the year because we usually ride after work and that last run can get a little cold once the sun gets behind the trees.
I've been playing in the boat for the last hour or so and I think I have some ideas, but it is going to require fabing up some brackets.
