Lifting rings
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=15897
Printed Date: November-18-2024 at 2:40am
Topic: Lifting rings
Posted By: Tom_Madison
Subject: Lifting rings
Date Posted: November-25-2009 at 1:59am
I am done sanding the hull and deck, ready to have the gel coat applied. I'm sure the shop doing the gel coat is going to want to use the lifting rings. The front steel that the ring bolts to is rusty and the fiberglass that is along that rust has totally delaminated. I was able to detach and clean up the long bolt. I'm guessing that the bolt is tied into the bow eye and some structure below, but the delamination has me spooked. The rear ring is also bolted to a totally rusted metal brace, which is also a bit bent up. I trust the place doing the gel coat to make the correct call on this, but anyone else deal with this rusted/delaminated support stuff?
Posted By: uk1979
Date Posted: November-25-2009 at 8:09am
Try this post.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=13224&KW=&title=would-you-use-your-lifting-rings - Lifting Rings
------------- Lets have a go 56 Starflite 77 SN 78 SN 80 BFN
Posted By: Marauder71
Date Posted: November-25-2009 at 2:21pm
I have a quick question for you all while we are talking about the lifting rings. Do you think it would be ok to tow a skier/wakeboarder with the stern lifting ring? I know it is built for lateral load characteristics but could it withstand horizontal stresses as well. My problem is I do not have a pylon and anything forward of the motor will be difficult due to the hardtop.
Posted By: connorssons
Date Posted: November-25-2009 at 2:29pm
I have a 71 mustang and been using the rear ring for all its life with no proublems. good luck! buy the way i love your boat. jeff
Date Posted: November-25-2009 at 2:41pm
Thanks for the imput Jeff.
I should have said vertical instead of lateral...wasn't thinking.
I found a thread on this site about pulling with the lifting ring and there are mixed reviews. I know this is not what it was designed to do but I don't know that I have much choice.
Posted By: SNobsessed
Date Posted: November-25-2009 at 8:41pm
David - I had the gel coat crack next to my front lifting ring because I used it for the extended pylon cable attachment. So while I don't think using your rear ring for towing would be unsafe, you might end up with an appearance issue.
