on board diagnostic tool
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=16292
Printed Date: November-18-2024 at 4:19am
Topic: on board diagnostic tool
Posted By: marc
Subject: on board diagnostic tool
Date Posted: January-15-2010 at 9:39pm
Hi Guys.
does anyone know if you can get a scan tool or on board diagnostic tool for the GT 40 motor.I believe that they have a special plug and an auto scan tool won't fit it.
My nephew has a nautique with the engine check light on ,and we need one of these tools.
cheers
marc from OZ
outbackski
Posted By: eric lavine
Date Posted: January-16-2010 at 11:52am
I thought it was obd2, can you take a pic of the plug to possibly identify?? my scanner comes with about 15 different connecters and to date i have not had the chance to scan a boat. how is the boat acting? as of 2010 ALL boats will be required to be catalyzed which will increase the price of the boat, thats here in the ole USA that is
Posted By: marc
Date Posted: January-16-2010 at 8:49pm
Hi Eric
The boat idles fine and runs up to 1500rpm ok,but as you increase rpm the motor surges,so much that you can't use it.
I do have pics ,but how do I insert them on the forum.can,t find an attach icon.
outbackski
Posted By: marc
Date Posted: January-16-2010 at 9:15pm
finally figured it out.
marc
outbackski
Date Posted: January-17-2010 at 1:11pm
that end looks very familier...earlier ford plug.
well to date on these ford injected engines weve seen alot of fuel pump issues and a bad M.A.P sensor, is there a schrader valve so you can check fuel pressure? it should be on the rail. if the reading is 2 lbs out the engine will give you problems.
the map sensor controls timing advance and a new one cured another guys issue like the one you are having. i think it is an auto part and not marine specific
Posted By: marc
Date Posted: January-17-2010 at 5:17pm
well after much frustration and bypassing ,finally it was the oil pressure sensor.with a scan tool it would have saved hours.
marc
outbackski
Date Posted: January-18-2010 at 10:37am
glad to hear
