Prop search
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=16307
Printed Date: November-19-2024 at 2:35am
Topic: Prop search
Posted By: rithmetic man
Subject: Prop search
Date Posted: January-17-2010 at 6:17pm
I am looking for a RH 12.5 x 13 or 12 x 12 prop for a 302 Nautique. Gently used is OK.
"Life is hard; It's harder if you're stupid...Pilgrim..."
John Wayne
1965 Nautique
Posted By: SS 201
Date Posted: January-18-2010 at 10:52am
I have 2 11 1/2 inch 3 Blades RH
I have 2 11 1/2 inch 4 Blades RH
These are all OJ props blue printed for my 351 81 Ski Nautique
beautiful props like new.
Call 407 367 8589 ask for Bill
Posted By: hotboat
Date Posted: January-18-2010 at 3:07pm
Bill what material are they made of and what performance characteristics do you remember from each? If you get a chance
Brian
Date Posted: January-18-2010 at 7:20pm
Thanks for the offer Bill but I think I need to hold out for a 12 or 12.5. We suffered trying to ski last summer with my '68 302 SN and hopefully the props recommended by a site member with the same type boat will fix the problem.
John Wayne
1965 Nautique
Posted By: WLKONH2O
Date Posted: January-18-2010 at 10:29pm
rithmetic man   I have a brand new OJ 12x13 RC 1" that is perfect for a 302. I can ship it to your door for $285   If you want it in SS I have one of those for $385. Race City Marine is home of Orange Crush! We support CCFAN! Let me know if I can help.
WLKONH2O <><
96 Ski Nautique
Race City Marine
Inboard Parts & Repair
Date Posted: January-18-2010 at 11:08pm
Thanks WLKONH20. I will pass the information on to my son and he will contact you. Thanks again. Wayne
John Wayne
1965 Nautique
Posted By: SS 201
Date Posted: January-19-2010 at 10:09am
The props are brass, they have 6 * rake letting the hull to have good lift. All 3 & 4 are great for ride pull power, speed. I believe the less dia run the boat without chine running.The 4 blade have good acceleration and speed, the 3 also pull and run straight, and speed. Now these props are for 1.1 gear ratio not the 1.23 box is another different story.
Posted By: SS 201
Date Posted: January-22-2010 at 8:56am
Also I had these props cut to get the 2 inches above the rudder. Under power lets you turn easier, also lets the prop work better. Most older Nautiqus the props are to far from the strut and the props are 2-3 inches below the rudder. This was changed on 1997 from my discussions with the power to be.
Posted By: hotboat
Date Posted: January-22-2010 at 10:42am
Cut? The bore opened up? I shortened my driveshaft 2.25", assuming same result...If I am misunderstanding this can you correct me Bill? Thanks
Brian
Posted By: SS 201
Date Posted: January-22-2010 at 3:31pm
Yes, the shafts were shortened to be about 5/8 of a inch behind the strut.gave the boat more running surface and a better ride, etc.
