Decals and paint...
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=16449
Printed Date: November-18-2024 at 8:51am
Topic: Decals and paint...
Posted By: inglesideshawn
Subject: Decals and paint...
Date Posted: February-03-2010 at 4:37am
all buffed out...
------------- 1989 nautique
Date Posted: February-03-2010 at 4:42am
Date Posted: February-03-2010 at 4:51am
3 coats of paint
Date Posted: February-03-2010 at 5:01am
Posted By: storm34
Date Posted: February-03-2010 at 1:39pm
Looks great! Love the colors of that 89...I had an 88 in the same color!
Date Posted: February-03-2010 at 1:56pm
the back
Date Posted: February-03-2010 at 1:57pm
Date Posted: February-03-2010 at 1:59pm
Date Posted: February-03-2010 at 2:01pm
Date Posted: February-03-2010 at 2:05pm
and got the new light bar 4 the abck, with tabs welded on 2 make the holes line up..
Date Posted: February-03-2010 at 2:25pm
gave up on the small sprayer and used the hvlp..
Posted By: Hollywood
Date Posted: February-03-2010 at 2:32pm
Nice work, so did you just tape off the super white gel?
Posted By: Okie Boarder
Date Posted: February-03-2010 at 2:37pm
Posted By: 79nautique
Date Posted: February-03-2010 at 2:58pm
looks nice but for future refernce the factory would have used this type of paint which is only available in gallon quanities.
www.grainger.com/Grainger/items/2ZLP3?Pid=search - www.grainger.com/Grainger/items/2ZLP3?Pid=search
not sure why the link isn't working
http://www.grainger.com/Grainger/items/2ZLP3?Pid=search
Date Posted: February-03-2010 at 3:35pm
http://www.grainger.com/Grainger/items/2ZLP3?Pid=search |
Its true that CC used Rustoleum paint for the lettering on the mid to late 70's boats. That may have spilled into the 80's as well since the stripes were painted until 84-85. The decals in question are the 87-89 variety though, and were originally vinyl. These are NLA so the accepted procedure is to paint them on now. Not sure if theres a Rustoleum color that matches the vinyl/gel colors from the late 80's or not.
Date Posted: February-03-2010 at 4:24pm
http://www.grainger.com/Grainger/items/2ZLP3 |
Chris,
I couldn't even find the item number! Which Rustoleum system # are you referring to?
Date Posted: February-03-2010 at 4:36pm
it's an industrial alkyd enamel, it took me a little to find it on there website back in the day and they've changed the site since then, the can is a little different too from when I bought it several years ago but I did get it from Grainger's
Date Posted: February-03-2010 at 4:44pm
Chris,
Looking at the Grainger catalog, there are four series of alkyd enamels. The only one with a different lable is the V6400 "Industrial Choice". Maybe that's the one you were referring to.
Date Posted: February-03-2010 at 4:58pm
http://www.rustoleumibg.com/product.asp?lvl=P&pnv=2&snv=1&pid=100 - paint
Posted By: storm34
Date Posted: February-03-2010 at 5:14pm
Threadjack for a sec...79, did you repaint your graphics? How much would a certain someone with a Ski Tique look at buying if he were to repaint his graphics?
Date Posted: February-03-2010 at 5:18pm
Chris, you may also want to ask the question to Jeff Toro (77 Nautique) as he repainted his boat last winter/spring. Saw the boat at Lake George (he won his class)... beautiful!
well it only comes in gallons for the correct paint so one gallon should do about three or four boats easy. If your's is safty blue I might be able to spare some provided what I have left is still good.
Back when I did repaint mine I did call CC and got the info and then talked to rustoleum and they where who directed me to the specific type of paint As I wanted to hold true to Pete and the Orginal theme, But I do see rustoleum has a topsider paint now that they didn't back then and I'm sure there are other brands and types of paint that would work just fine and look the same.
Posted By: storm34
Date Posted: February-03-2010 at 5:30pm
Thanks gusy, Tim...Thanks for the name, i was actually going to email you and ask for the thread as I couldn't find it. I bookmarked the page and will get ahold of Jeff.
79, I may have a buddy who would buy some with me, he's got a southwind in need of some repaint as well.
Sorry Shawn, Back to your 89...looks awesome!
Date Posted: February-03-2010 at 5:33pm
Chris,
So you used the "DTM" (direct to metal). I never thought too highly of the paint. Always thought of it as being a "quick and dirty" method for a contractor to skip the primer. We have used the stuff here at work but notice rust has started to bleed through. However, since it's made to stick to metal without a primer then I would think it would stick to glass as well. Plus, you won't have a rust issue with fiberglass!!
Was this DTM recommended? I think most are just going to the hardware and getting a quart off the shelf. In this case Rustoleum "Safety Blue". Adhesion problems haven't been mentioned yet!!
You are correct that the DTM has a blue label in place of the standard alkyd's red.
Date Posted: February-03-2010 at 5:49pm
Pete I would have to check the can that I have over in the barn, Like I said it looks like they changed it from when I bought mine, I don't recall the DTM being on the label but it was for concrete and metal and I questioned them about that and they said no problem above the water line. Without looking at the can of paint for the exact info but what I recall is industrial Alkyd enamel paint, pretty thick stuff and it needs to be thinned out to use and have it look good.
But if I was doing it today I would just use topsider paint mask it off and spray it. Might pick Allen's brain he repainted his about the same time and I thought he used Rustoleum as well.
Date Posted: February-03-2010 at 6:08pm
79nautique wrote:
Pete I would have to check the can that I have over in the barn. |
Check out the can. I'm curious! I only mentioned the DTM Rustoleum because that's the link you provided.
Posted By: Tim D
Date Posted: February-03-2010 at 6:27pm
As far as masking, I would use 3M's tape called the Edge. Blue painters tape gives no better hard-edge than masking tape. But I don't know anything and I'm Chinese.
------------- Tim D
Date Posted: February-03-2010 at 7:35pm
the fine line tape works excelent,kind of a shame to cover it up with a pinstripe.. as for the paint its just rustoleum,with a hardner and thinner added..scuffed up with 320..
Date Posted: February-03-2010 at 8:18pm
inglesideshawn wrote:
the fine line tape works excelent,kind of a shame to cover it up with a pinstripe. |
Shawn,
Glad you used the fine line tape. You're correct it is good stuff! Looks like you used the 4737 because of the blue color. It's their vinyl "fine line". Any reason for picking that type? I've always used the 218 Polypropylene which has that light green color.
For technical referrence:
http://multimedia.mmm.com/mws/mediawebserver.dyn?lllllNAsDx&leqtNeq2NhRMlZXf4eWOvZ5MlZ5M4LLLLL - 4737 fine line
http://multimedia.mmm.com/mws/mediawebserver.dyn?GGGGGIwnzS7G9lovDMoSAjHGU6Ag9R3qUjHGUjHg22222 - 218 fine line
http://www.jamestowndistributors.com/userportal/search.do?freeText=fine%20line%20tape&resultPref=all&page=GRID&history= - 218 fine line at Jamestown
Date Posted: February-03-2010 at 11:31pm
ive had good luck with the blue tape.. the larger size helps with removal,less chance of breaking..
Date Posted: February-17-2010 at 3:05am
Date Posted: February-17-2010 at 3:07am
Date Posted: February-17-2010 at 3:11am
Date Posted: February-17-2010 at 3:32am
dident put the shadow on, its just got a good simple clean look...
Date Posted: February-17-2010 at 2:32pm
Date Posted: February-17-2010 at 2:36pm
back with the top stripe still to do..
Date Posted: February-17-2010 at 2:38pm
if i was to make the side decals again they would be a 1/4in bigger to cover the gel fade easier...
Date Posted: April-19-2010 at 2:29pm
not wanting to cut the coming pads,this is what i came up with for the speaker locations, the passenger seat base worked good and dosent sound bad with the seat over part of them..
Date Posted: April-19-2010 at 2:33pm
all done and waxed up......
Date Posted: April-19-2010 at 2:59pm
Looks good. I bet the speaker sound pretty decent in that location.
Posted By: storm34
Date Posted: April-19-2010 at 3:21pm
Looks great! If you want to finish off those guide poles, I used black piping from our irrigation system. I got it from my boss at the time, a landscaping place. It looks much better than the white, in my opinion.
