1990 PCM ENGINE PAINT
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=16507
Printed Date: November-18-2024 at 5:41am
Topic: 1990 PCM ENGINE PAINT
Posted By: SASHAY1939
Subject: 1990 PCM ENGINE PAINT
Date Posted: February-10-2010 at 6:29pm
I looking for a source or paint code for the silver engine paint used by PCM in the late 80's -early 90's.
Posted By: Fl Inboards
Date Posted: February-10-2010 at 6:40pm
Rustoleum!
Posted By: 82 Nautique 1
Date Posted: February-10-2010 at 8:20pm
High temp ? Part # Color #
Original Owner " Dennis"
http://www.correctcraftfan.com/diaries/details.asp?ID=4855" rel="nofollow - 1982 Nautique
Date Posted: February-10-2010 at 9:09pm
Last I checked, SkiDIM sells it.
Posted By: kapla
Date Posted: February-10-2010 at 9:36pm
no need for high heat..regular paint will do just fine...just make sure all surfaces are clean and degreased..if not paint will not hold and will peel off when dry....
<a href="">1992 ski nautique
Posted By: eric lavine
Date Posted: February-11-2010 at 9:49am
take a painted piece to your local auto body supply store, they may be able to use a color eye and get you close, fwiw, i use bc/cc to paint engines good up to 350 degrees and to date...well its durable
