NEED RUNNING GEAR FOR 1988 MARINIQUE
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=16619
Printed Date: November-19-2024 at 12:18am
Topic: NEED RUNNING GEAR FOR 1988 MARINIQUE
Posted By: bluebird88
Subject: NEED RUNNING GEAR FOR 1988 MARINIQUE
Date Posted: February-23-2010 at 3:33am
PARTS NEEDED FOR 1988 MARINIQUE C/B WITH 351 FORD, 1:1 BW TRANS
#1 BUCK ALGONQUIN RUDDER PORT - 1 1/4" SHAFT, BASE 3 1/4 X 4",
4 3/4" HIGH, MARKED 10RP125ACC, BASE PLATE MARKED B-A RPBP100/125CC
#2 RUDDER - 1 1/4 " SHAFT
THIS ALL I HAVE ON SIZE AS IT IS ON THE BOTTOM OF THE LAKE STILL
KISSING THAT LOG. IF A CCFAN HAS SIZES OR A GOOD PHOTO FROM A
MARINIQUE I WHOULD LOVE TO HAVE THE INFO.
#3 SHAFT - 41" OVERALL, ONE TAPERED END, 1" SHAFT, 3 3/4" TO
START OF TAPER, KEYWAY BOTH ENDS.
#4 STRUT, MARKED 8A-8 J - BASE 5 3/4" X 3 3/8", 6" BARREL
#5 DAMPER PLATE FOR FORD 351, 1:1 BW TRANS, 26 SPLINE
#6 FLYWHEEL, 13 1/4" ROUND, 157 TEETH - STAMPED C87E
#7 OIL COOLER
EMAIL ME INFO, COST IF YOU HAVE PARTS, THANK YOU, CWWFIREREPAIR@AOL.COM
------------- cww
Date Posted: March-08-2010 at 12:09am
THIS IS BLUEBIRD88
I ALSO NEED A STEERING CABLE FOR THE MARTINIQUE
AND A USED - ACME 4 BLADE PROP
-208 - 13x12.5 V RH 1"
THANKS
CWW
------------- cww
Posted By: eric lavine
Date Posted: March-08-2010 at 10:05am
I can come up with, damper, possibly FW, and cooler
Date Posted: March-09-2010 at 1:17am
I WILL BE PICKING UP THE NEW DAMPER AND COOLER FROM FRDERAL MARINE IN CHICAGO ON WEDNESDAY. STILL LOOKING FOR THE OTHER PARTS
IS THE FLYWHEEL NEW OR USED AND FROM WHAT YEAR AND MAKE OF ENGINE
WHAT IS THE COST ALSO
------------- cww
Posted By: Andy
Date Posted: March-09-2010 at 1:24am
Why all the yelling?
------------- http://correctcraftfan.com/diaries/details.asp?ID=3721&sort=&pagenum=6&yrstart=1982&yrend=1982" rel="nofollow - My Blue 82 SOLD!
Posted By: kapla
Date Posted: March-09-2010 at 5:19pm
Andy wrote:
Why all the yelling? |
writing in capitals is understud as yelling!!! GOT IT???
Posted By: Seperator
Date Posted: March-09-2010 at 9:04pm
Please turn off the CAPs lock Bluebird88 we are not deef
Posted By: wakeboardin2k4
Date Posted: March-09-2010 at 11:46pm
I have an acme 540 if you wanna try a 3 blade with your martinique. Its got the same pitch and size
------------- "I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Posted By: connorssons
Date Posted: March-10-2010 at 3:04am
I haave a 77 martinique, shaft, rudder and strut, if it will fit make me an offer
Date Posted: March-10-2010 at 10:31am
Bluebird tell Jimmy Aspel at Federal, Eric from FFI or Great lakes Power said hi, did some jobs up at skipperbuds with him a few years back....watch out he will pull the dial indicators out on you, and you will be walking out of his shop with prop savers, federal couplings and to the likes.
I need to look for the FW, you need the weight offset FW?
Date Posted: March-10-2010 at 9:18pm
caplocks off
I due not know if the parts from a 77 will work, the strut will have a cast stamp on the barrel - 6 A 6 J - and the size listed above. If you have the rudder port look for the size listed above or maybe help from cc members.
The flywheel looks good - only have two worn teeth 1/32" on the ring gear and do not want to have a problem later on.
Did not get in to see jimmy yet. I will relay the info. also He did get me for the flex coupling
------------- cww
Date Posted: March-10-2010 at 10:50pm
press on a new ring gear, 26 bucks from crapa or bonerzone, flex coupling? he isnt trying to talk you into a prop saver or federal coupling is he?
Date Posted: March-10-2010 at 10:52pm
Will check on numbers tomorrow
Date Posted: March-11-2010 at 10:28am
count the teeth, air hammer off and then heat the new one up and drop it on.....unless you want to buy a new FW?
Date Posted: March-11-2010 at 10:34am
I went up to skipper buds and pulled a trans, rebuilt it on the tailgate of a pick up truck and put it back in on the same day for Paragon Power, he was there, nice guy. we ended up having seal ring problems in the transmissions, a touch to big.
Date Posted: March-18-2010 at 11:52am
connorssons
Did you have time to look at parts numbers ( 6 A 6 STRUT )
THANKS CWW
------------- cww
