Ignition Switch
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=17189
Printed Date: November-18-2024 at 8:24am
Topic: Ignition Switch
Posted By: jimsport93
Subject: Ignition Switch
Date Posted: April-19-2010 at 1:17pm
My ignitions switch gets loose and spins around. Tried to tighten it, but it keeps getting loose again (it is OK with me driving...but others are more heavy handed).
Any tricks you can suggest to keep it tight? Thread locker...etc?
It is on my '93 Sport. Mounted on the dash panel.
http://www.correctcraftfan.com/diaries/details.asp?ID=2798 - 93 Sport Nautique
Posted By: Morfoot
Date Posted: April-19-2010 at 2:20pm
Jim, add another washer under the nut. You may want to try using/changing a star type lock washer. You'll probably have to disconnect a couple of wires but should be pretty easy. Just make sure you remember where the wires go when you take them off.
Date Posted: April-19-2010 at 3:57pm
Tim,
That should work great. I knew that there was a solution I was overlooking
Thanks
Posted By: skicat2001
Date Posted: April-19-2010 at 9:40pm
I hate that when it happens.. Adding a washer works, I did that and now the whole assembly is fully intact.. Works great! :)
1985 CC 2001-SOLD
Lee Michael Johnson
