Rub Rail Rope?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=17229
Printed Date: November-18-2024 at 11:19am
Topic: Rub Rail Rope?
Posted By: SNobsessed
Subject: Rub Rail Rope?
Date Posted: April-22-2010 at 10:36am
Guys - I searched for info on best rope to use but didn't get anything specific.
I don't want to use a cotton rope due to mildew concern.
I got a sample of polypropylene braided rope, but it is very soft, looks like it will pill easily, & does not retain well in the rubrail groove.
Searching the 'net, it looks like I should get 'twisted polyester' rope.(sounds like a punk disco band!)
Is this the best choice? I couldn't find a source other than 500ft length.
Any advice is apreciated.
Chris
Date Posted: April-22-2010 at 11:35am
Chris, I replaced the rope in my Tique rub rail with a 50' twisted poly rope from Home Depot. I was planning to do the same on the BFN. If you cant find the right size locally (I think yours takes 5/8"?) then N3boatworks or another dealer should be able to get it for you.
Posted By: Morfoot
Date Posted: April-22-2010 at 11:43am
Chris, I did my 88' last fall with rope I got from Lowes. So far so good on it holding up. I put the boat in the hot sun fo a couple of hours before starting the installation and was able to pop the new rope in with my fist. Don't throw away your old toothbrush. Use it to clean the channel real good before you put in the new rope as mine was a science project in the making.
Posted By: storm34
Date Posted: April-22-2010 at 1:12pm
Great info! I pulled mine out last night and will be doing the same!
Date Posted: April-22-2010 at 1:14pm
Chris (Storm)- just in case you didnt measure, the Tique uses the smaller rub rail, which takes a 1/2" rope. Our BFN uses the larger one, which looks to be the same as the 87+ SN's... I *think* the rope is 5/8" but havent pulled ours out yet.
Posted By: storm34
Date Posted: April-22-2010 at 1:34pm
Thanks Tim, I've got the old one with me to match. I was just glad to hear I could get it at HD or Lowes!
Posted By: 79nautique
Date Posted: April-22-2010 at 2:30pm
I used the braided nylon/polyester 5/8" rope on mine went in easy held up great was able to get it in a blue and white color to match the boat looked much better the the twisted rope that was in it.
Date Posted: April-22-2010 at 9:10pm
Thanks guys, will head to HD & Lowes this weekend.
Posted By: DrCC
Date Posted: April-22-2010 at 9:23pm
So, no one's tryed the "Glo-in-the-Dark rope yet?
Changed mine last year 1/2" White twist Nylon, 18.00 and change, just the other day I noticed it went up to 26.00 and change for 50 feet. (Lowes)
Posted By: DrCC
Date Posted: April-22-2010 at 9:28pm
I do have a use for the rope that I took out.
My neighbor just bought a 1990 Stingray 250 MerCruiser.
        (Tow-rope)
I can almost smell the phone calls already.
Date Posted: April-22-2010 at 9:57pm
Al, You may want to check over on PN.com or Wakeboarder.com and see. I'd say there's a good chance someone has!!
Posted By: DrCC
Date Posted: April-22-2010 at 10:07pm
hahaha! I actually thought about it for a half a minute.
The Green glo probably wouldn't be a bad idea on this lake.
But..... until they make Red glo for the port side.
I don't go out at night anyway.
AT
Date Posted: April-22-2010 at 11:57pm
Hmmmm
2-Wire 1/2" (13mm), LED Red Rope Light
Posted By: Hollywood
Date Posted: April-23-2010 at 10:38pm
Bling Bling
Date Posted: April-24-2010 at 10:10am
Chris,
I think you should post that picture on the other sites and see if anyone will go for it! Did they have it in green? White of course for the aft end!
Date Posted: April-25-2010 at 7:32pm
Back to the serious side -- I took the rub rail off. Somebody had sealed up the gap with silicone seal so I dug all that out (tedious). I resealed the gap with 3M 4200, along with all the holes & rivet heads (some were pulled through).
We remounted the rub rail, using the old screw holes. Got 1 side done & it looked terribly wavy. I pulled it back off before the 4200 fully cured.
Looking a White Lake website, it looks like new rub rail runs about $500. Haven't budgeted for that.
Any chance that the old rub rail will go on straighter if I drill new holes? I was thinking of putting some short 5/8 rods in it to help hold it straight during mounting.
I will need new inside screw-backer plastic, it is now pretty torn up (maybe that was the problem) - any idea if I could buy that somewhere separately?
Posted By: DrCC
Date Posted: April-25-2010 at 9:19pm
Chris,   Are you tightening the screws?
The wavyness may be coming from having the screws too tight.
The screws are only to act as a hanger.
AT
Posted By: skicat2001
Date Posted: April-25-2010 at 9:32pm
I am guessing you guys are talking about the rubber pieace that runs around the boat.. Right?
I have a black rubber one that runs around and would like to upgrade to the one with the rope inside the black rubber. How do you install, and take off the old one? Is it just as simple cut and pull method? What kinda glue do you use, and who can you order this from? Any advice from the pros would be great..
Thanks
Lee
1985 CC 2001-SOLD
Lee Michael Johnson
Date Posted: April-26-2010 at 2:27am
Al - Yes, I tightened the screws pretty good.    Now that you mention it,I think that may be the problem.     I was thinking the inner plastic strip, which is now in about 20 pcs, was supposed to keep it straight.     Does that inner strip provide any stiffness or just act as a spacer for the rope? If I need to replace it I will have to get resourceful to find a substitute.
Lee - Post a photo of the rubrail you have now & maybe we can help. You probably have one with a vinyl insert - if so that can be pryed out with a screwdriver. Then you can take out all the screws to remove the moulding. I am still trying to figure out how best to remount it though!
Date Posted: April-26-2010 at 2:26pm
I sure will Chris.. Thanks...
1985 CC 2001-SOLD
Lee Michael Johnson
Date Posted: May-03-2010 at 1:14am
Al (Dr CC) - Thanks for your advice. I limited the torque when we remounted the rub rail & only tightened the screws up to the point of good contact. That, coupled with oversizing the holes in the rubrail so it could be finessed, helped a bunch.    I really didn't want to drill a new set of holes in the hull - it had 2 sets already.
The rubrail isn't as straight as I would like, but good enough. It probably wasn't straight before I took it off - once you get to looking at something it draws your eye right to the imperfection!
Funny, the rail is about now 2 inches shorter than when it came off. The material must have shrunk over the years. The end cap covers up the gap so it isn't a problem.
Mission accomplished.
Posted By: fanofccfan
Date Posted: May-03-2010 at 9:35pm
just wondering...can the plastic tube that was in my 96 be replaced with a real rope? i never liked the idea of going away from the real rope when they went to the plastic stuff, just did not look right in my mind. old school perhaps.
Posted By: tommer12
Date Posted: May-05-2010 at 3:14am
I did my 84 and it was horrible.   I made a special tool out of wood that pried the rub rail apart while someone else slipped the rope in. The older boats, the rubber is less pliable. So to open it up to put in a new rope was less fun. Lots of dawn soap and my little wooden tool and it start to slip right in. I could have taken the rail off, but i didnt want the chance the screws didnt go back in not aligned straight, etc. Post some pics!
I also wondered if you could take out the rubber insert (Like my 92) and put a rope one in and what it would look like. Be kind of cool
84 SN, 92 SNOB, 2005 SANTE 2006 SN 206
