tight steering
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=17283
Printed Date: November-18-2024 at 11:48am
Topic: tight steering
Posted By: 93SNautique
Subject: tight steering
Date Posted: April-26-2010 at 12:49pm
A friend of mine has a 96SN that has a steering problem. The steering seems fine when the boat is not moving, but when under power (like at the end of the course), you need two hands to turn the wheel.
We disconnected the rudder and did the cable test. Both the wheel and the rudder move freely but as I said before, there really isnt any resistance until the boat is moving.
Dont really want to spend the money to replace the cable if that doesnt fix the problem.....?
Anyone seen this before or have an idea of why the wheel is so difficult to turn under power?
thanks,
http://www.correctcraftfan.com/diaries/details.asp?ID=1458" rel="nofollow - My 93
Posted By: 79nautique
Date Posted: April-26-2010 at 1:50pm
has the rudder been changed recently?
Date Posted: April-26-2010 at 5:15pm
My friend just bought this boat a few weeks ago....but from the looks of it, I would guess the rudder to be original. We can try to check with the PO.
What are you thinking 79?
Posted By: kapla
Date Posted: April-27-2010 at 1:19am
is it hard to turn to both sides? mine turns fine to port but hard to starboard....
<a href="">1992 ski nautique
Posted By: storm34
Date Posted: April-27-2010 at 2:35am
I'd start by check out your packing and lock nuts. Mine were loose on the 96 SNOB. The rudder would spin fine one way and catch and bounce going the other way.
My cable felt alright when I took it off the rudder but i went ahead and changed it out since we'll be keeping the boat a long time. It turns smooth as silk now.
Posted By: storm34
Date Posted: April-27-2010 at 2:42am
also, check your wax packing rope and grease the rudder when you take it all apart. It's pretty easy once you get everything out of the back of the boat.
Date Posted: April-27-2010 at 12:51pm
Actually it is hard to turn to either side.
I think the next move is to check the nut and packing.
Posted By: jayc
Date Posted: April-29-2010 at 6:18am
Drop the rudder and grease it if no grease ports are on the tube.
Had this on a couple of nautiques even after replacing steering cables. About an hour to drop the rudder, clean out the old grease, repack and safety it all up.
Well worth it as you'll have super light steering again.
1982 Nautique 2001 - 351W Dual Fuel
1982 Ski Tique - 351W Dual fuel
1996 Maxum 210ss -350 EFI Dual Fuel
Date Posted: April-29-2010 at 12:20pm
I would say the cable is stiff from not being moved during lay-up and it being new to you. There isn't a zirc fitting to grease the rudder port there's not really a need for one, some have added them I personally feel it's waisted grease polluting the lakes as it gets washed out as soon as you take off but to each there own.
Some have removed the cable and lubed it up and it's freed up the steering. Also since it's new to you it just might be an old cable that needs to be replaced. Orignally the thought was something was changed like the rudder and that the water wasn't flowing over both sides of the rudder at the same rate due to manufacturing, think of it as a air foil where one side is humped more than the other causing a pressure differencial from one side to the other, this effect gives the feeling of hard steering to one direction vs the other.
