Idle Oil Pressure?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=17419
Printed Date: November-18-2024 at 11:48am
Topic: Idle Oil Pressure?
Posted By: rmm025
Subject: Idle Oil Pressure?
Date Posted: May-06-2010 at 1:31pm
86 SN 2001 - 351 PCM
I have finally got my carb running consistently, and I set my idle at 500rpm. When at idle, my oil pressure bounces from 20-25psi. I have never noticed it that low before, but I have also never been able to hold my idle that low either.(I have chased a leaking venturi for a while that made my idle swing +/- 400rpm) When running 2000rpm:40-50psi, 3000rpm:50+psi, 4000rpm:40-50psi. I think I may need to bump up my idle to 750ish. I didn't try it yesterday, but it may pick up my idle oil pressure. I guess my question is what should my idle oil pressure be, I know I am fine when running, but the idle pressure made me nervous yesterday.
Posted By: malibud
Date Posted: May-06-2010 at 3:04pm
Thats what mine is when I m running about 4000 rpm I am at about 60 bit at idle iam about 20-25 I think that is ok less than 15 is trouble
Posted By: 79nautique
Date Posted: May-06-2010 at 3:17pm
idle should be set at 650 in gear 500 is too low.
Posted By: rmm025
Date Posted: May-06-2010 at 5:09pm
As long as 20-25 idle rpm is ok I am fine with that, like I said just never remembered seing it that low even though it might have been that way all along.
I plan on setting the idle higher, because I ended up dying going from idle to reverse one time.
