Shaft Log Hose
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=17427
Printed Date: November-18-2024 at 10:30am
Topic: Shaft Log Hose
Posted By: Jim_In_Houston
Subject: Shaft Log Hose
Date Posted: May-06-2010 at 11:42pm
Hi all. I've been MIA for a while. I am getting back to my '68. It hasn't been in the water nor ran since two hurricanes ago.
I am replacing the shaft log hose and the replacement hose has thicker walls than the original. I am having great difficulty sliding the new hose onto the shaft log. The hose fits the seal portion perfectly. Anyone know of a hose expansion tool or have any tips? I have beveled the ID edge of the hose to a 45 deg angle with a Dremel tool. I have used soap for lube, I have boiled the hose in water to try to soften it. No luck on anything. I have even tried an old metal shoe spoon. It just won't go.
Posted By: DrCC
Date Posted: May-07-2010 at 1:29am
If it's not wire reinforced, soap should work just fine.
AT
Posted By: BuffaloBFN
Date Posted: May-07-2010 at 11:11am
Do you have a 8lb mushroom anchor or the like? Try the center post(tie-off point).
http://correctcraftfan.com/diaries/details.asp?ID=2331&sort=&pagenum=12&yrstart=1986&yrend=1990" rel="nofollow - 1988 BFN-sold
Posted By: Riley
Date Posted: May-07-2010 at 11:44am
Jim, I remember talking about this last year. I wrestled with my 66 for a few months before I found some decent hose. I tried wire re enforced fuel line hose and pre cut shaft log hose from a marine web site. I boiled it, reamed it and beat it with a hammer and still could not get it to go on. I finally found some good quality non wire re enforced hose at NAPPA that worked great. I've taken 3 boats apart that all appeared to have the original shaft log hose on them and none were wire re enforced and they were not nearly as good of hose as the stuff from NAPPA. I think I could have gotten the wire re enforced hose on if I had extended the length by about an inch. A friend of mine that owns a glass shop gave me some spray silicon used for installing glass and it is great for lubricating hose.
Posted By: WakeSlayer
Date Posted: May-07-2010 at 12:27pm
I beat the living daylights out of the wire re-inforced I installed on the Mustang. I finally got it far enough on to double clamp and called it good. I would probably settle for non re-inforced next time. Like Bruce said, it is far better than the original and that lasted 40 years.
Mike N
1968 Mustang
Date Posted: May-07-2010 at 3:24pm
After fighting the hose for a full day I decided to try and (emphasize "try")use my brain. I turned the prop shaft coupling around and used a couple of pieces of all-thread to act as jacking screws. I applied soap to the ID of the hose and it went on effortlessly. Well, it is actually only on about 1/4" and I ran out of all-thread length. Its off to the hardware store to get a longer piece of all thread.
Not seen is a piece of PVC pipe I slipped inside the hose and shaft log to act as a guide.
Posted By: Riley
Date Posted: May-07-2010 at 3:28pm
That's a good idea. I think what happens as the hose tries to overcome the wide part of the log, the wire stretches and hour glasses the hose making it near impossible to slip on. Good luck. I hope you don't warp your flange.
Date Posted: May-07-2010 at 3:38pm
Jim,
Great idea!! Yes, that's using your brain!
Posted By: 79nautique
Date Posted: May-07-2010 at 4:18pm
aaaaahhhhhh the old work smarter not harder theory..
Posted By: Keeganino
Date Posted: May-07-2010 at 4:32pm
Good trick since I am about to have to do the same thing. Thanks for the excellent post!
Date Posted: May-07-2010 at 8:27pm
The shaft log hose is on! It went surprisingly easy. For all you mid-60 Mustang owners I used 3/8" all-thread cut to 9 " which turned out perfect. When I got back from the hardware store I went ahead and used 4 pieces for an "even pull" but it was not necessary. You can see two of the nuts are not even pulled up. Also, note that I beveled the inside edge of the hose to a 45 deg angle with a Dremel tool and I applied lots of liquid soap to make it slippery. I also ran the Dremel tool around the outside edge of the shaft log to knock off the sharp edge which was digging into the inside of the hose when I was trying to force the hose on by hand. The PVC pipe was slipped in to keep the hose from buckling under pressure from the jack screws. You can see it in the photo. I slipped the prop shaft in (from the rear) and let it "hang" in the shaft log to keep the PVC pipe from falling all the way through.
Date Posted: May-11-2010 at 3:51pm
I have a 73 skier and am about to do the same thing so I want to clarify a few details of your method.
1. The PVC is inside the hose while you are doing this and you need the prop shaft hanging to keep it from falling out. Is there a reason that you had to use the pvc pipe and not just the prop shaft itself to keep it from collapsing?
2. Did you use the same method to push the shaft seal nut onto the hose?
Thanks again for sharing your great idea with us!
Date Posted: May-11-2010 at 4:47pm
Keeganino,
The pvc pipe fits loose inside the hose but it is larger in diameter than the prop shaft. I did not think of using the prop shaft - that may work too. The hose definitely buckles without something to prevent it from doing so. I just happened to have the pvc laying on my bench from a water well project and it fit inside the hose and shaft log so I grabbed it. Also, in the back of my mind, I figured that if the pvc got jammed inside the shaft log I could get it out by some means. (Drilling, sawing, chewing, chomping... etc)
I did not have to use any pressure to get the shaft seal nut on. I used 3 layers of new packed which was wax impregnated as it arrived from SKIDIM. I tamped the packing tightly into the nut by placing a large bolt through the nut and pressing down on the inside diameter of the packing all the way around. I could see when I had the packing don even with the edge of the nut. One mistake I made a long time ago was to cut the packing so the cut edges came together inside the packing. This time I cut the packing so that there was about a 3/32" gap between the edges and it fit much nicer. I placed the 3 cuts 1/3 of the way around the packing nut from each other. I pulled the prop shaft out of the way and screwed the packing nut onto the shaft log a couple of turned. I pushed the prop shaft through the nut while turning the prop shaft slowly and lightly tapping on the end of the prop shaft with a 2 x 4. It slipped through the packing nut with some resistance but not much. I checked the end of the prop shaft for bits of packing material and there was none so I figured I did not tear up the packing with the shaft. Let us know how the project went. Be sure to bevel the inside corner of the hose with sand paper, a round file, or a dremel tool with a round sanding bit. Add lots of liquid soap. Sand off the sharp edge on the end of the shaft log is there is one (like on mine).
By the way, I chose a double-layered reinforced hose that does not have wire inside.
