warning light??
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=17451
Printed Date: April-13-2025 at 2:02am
Topic: warning light??
Posted By: badstreetrod
Subject: warning light??
Date Posted: May-09-2010 at 10:23am
Good morning and thanks in advance for the help. Recently purchased a 92 ski natique that had not been used in a while and needs some repair, carb overhaul cleaning , interior etc. While running the boat yesterday noticed the temp gauge inop, quick check showed not connected this is the sending unit behind thermostat housing grounded the wire gauge reads full scale, someone has tried to replace it with an auto sending unit but even its wrong looks like a coolant fan unit has 2 spade connector, my real question is what is the other sending unit with tan or biege wire it appears to also connect to the oil pressure unit oil pressure works , guessing these go to idiot light somewhere but where??anyone have idea on gauge manufactuer or #for sending unit thanks again
------------- boattrader
Posted By: LaurelLakeSkier
Date Posted: May-09-2010 at 10:32am
Welcome to CCF!
Here's a http://www.correctcraftfan.com/forum/forum_posts.asp?TID=13706&KW=wiring+diagram&PID=158249&title=electrical-question#158249 - Link to a wiring diagram that might help you out.
Date Posted: May-09-2010 at 10:41am
thanks for the info will see what that does
Posted By: Hawktique
Date Posted: May-10-2010 at 11:19am
Hopefully these can help as well. I was also victim to the previous owner's lack of quality electrical work and have since rewired pretty much everything.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=17468&title=temp-volt-oil-alarm-tutorial - Alarm tutorial
http://www.correctcraftfan.com/downloads/1989_SN_Wiring_Diagram.pdf - Under Dash Wire Diagram
------------- "A Veteran is someone who at one point in his life, wrote a blank check made payable to: 'The United States of America,' for an amount of 'up to, and including his life." Semper Fi
Date Posted: May-10-2010 at 2:48pm
Thanks for the help guys, have discovered a lot about the boat in last few days, also not real happy about the protec ign it works now but for how long???????Does anyone know if the conversion skidim sells uses the mallory magnetic pickup or unilite???? unilite was junk on the hot rods sure it is the same on boats thanks again
Posted By: 79nautique
Date Posted: May-10-2010 at 3:13pm
badstreetrod wrote:
Thanks for the help guys, have discovered a lot about the boat in last few days, also not real happy about the protec ign it works now but for how long???????Does anyone know if the conversion skidim sells uses the mallory magnetic pickup or unilite???? unilite was junk on the hot rods sure it is the same on boats thanks again |
the optical pickup is by far superior to the magnetic pick-up BTW.
Never had any issue using it.
Also give Karen a call with MyCorrectCraftParts.com and order the conversion kit from them.
Date Posted: May-10-2010 at 3:24pm
thanks for the reply we had issues in hot rods with it maybe a new design by now will check with karen on it should the present system be replaced even though no issues with it, I know if it aint broke dont mess with it but ,,,,,,,,,,,,,,,,,,,,,,,
Date Posted: May-10-2010 at 3:28pm
what issues did you have?
Date Posted: May-10-2010 at 3:32pm
the cars just quit, replaced with msd or magnetic system never gave any more problems local hot rod dealer quit selling them for that reason they had warranty but that did you no good on the sid eof the road on sunday afternoon
Date Posted: May-10-2010 at 3:43pm
sounds like someone burned up the module because they didn't use the required balast resistor the system requires, Very common on a chevy motor since GM never used them on any model engine.
