GT40 Engine Layout
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=17789
Printed Date: November-18-2024 at 12:39pm
Topic: GT40 Engine Layout
Posted By: ChrisNautique
Subject: GT40 Engine Layout
Date Posted: May-31-2010 at 12:22pm
Hello,
I have a 97 Ski Nautique with GT40 engine. I would like to check out the impeller and it's condition. Where can I find a engine layout for PCM GT40 engine tofind out location of impeller and how to replace?
------------- Chris
Posted By: 81nautique
Date Posted: May-31-2010 at 1:39pm
http://correctcraftfan.com/Downloads/Pro_BOss_GT-40_Service_Manual.pdf - manual
------------- You can’t change the wind but you can adjust your sails
Date Posted: June-01-2010 at 11:13am
I appreciate you sending the manual however there is not info about water pumps, impellers et...
------------- Chris
Posted By: horkn
Date Posted: June-01-2010 at 12:25pm
Yeah, I read through all of that as well. No mention of the raw water pump or impeller. That manual is basically a manual about the efi system.
I've never looked at the rwp on a gt40 motor, but I would assume it is in the same place as it is on mine. It will be on the starboard side of the motor right in front, and about 3/4 the way down the motor. It's run off the belt drive. These are pretty simple, only a couple bolts hold the housing together, and the you can take the cover off and you can pull the impeller out by hand.
Install of a new one is the reverse of the removal. Some people put a little dish soap on the new impeller to get it lubed up for when it starts up the first time.
------------- 78 martinique- refloored, reinforced, stringers re glassed, re engineered interior
